Old 05-01-2009, 04:31 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Re: Replacing rear struts
Originally Posted by redlightningsvx View Post
I finally got my rear springs today and removed the old ones out. With the struts out the right rear I pressed down and it came back up so that was good but, when I got to the right rear I pressed the strut down and it wouldn't come up so I just ordered a new one and the foam helper as it was destroyed in the blown strut. Good news is the car sits A LOT higher like it should. My tires were literally touching the wheel well now it sits about 2-2.5 in above
Enjoy your year with working struts in the rear. Then you'll need to spend another $200ish to replace 'em both again.
Old 05-01-2009, 07:38 PM
redlightningsvx's Avatar
Collision Refinishing Tech
I know but it's the best cost effective option as of now.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 05-02-2009, 12:50 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Sometimes, this can be more expensive in the long run.
Old 05-02-2009, 06:56 AM
SVX_MY_BABY's Avatar
Keep your old struts to use for cores for Koni inserts. If you don't use them I'm sure someone else will want them.
Old 05-02-2009, 09:06 AM
AyeJaye's Avatar
AyeJaye AyeJaye is offline
Look at it this way. Now you have a set of struts sitting outside of the car, so that when you decide to get the Konis you don't have to be without a car while you do the switch
92 LS-L, Ebony Pearl, 160k miles, sitting in the hospital waiting room hoping for a miracle
06 Hyundai Sonata GLS, 77K miles
Old 05-02-2009, 09:41 AM
Yea, like I said I really would like to get the konis now but my money is being spent on fixing worn parts.
Seth
Past subies:
Other toys:
Old 05-02-2009, 10:14 AM
AyeJaye's Avatar
Do you know the part numbers of the replacement mounts, and where the best place to find them is? My rear end is sagging a bit too (though nothing is rubbing yet) and I'd like to get it fixed soon.
Old 05-02-2009, 10:55 AM
The top mounts? I would stuff your hand up in the wheel well and feel the back of the mount for holes as that is the first place it rusts. If those are good then go for springs as they are cheaper than the mounts.
Seth
Past subies:
Other toys:
