Heat to Electric Energy
I saw this and thought of quite a few practical applications:
http://www.trnmag.com/Stories/2001/1...er_121901.html If at 40% efficiency, with the size of the diodes, you were to place several thousand on your car, you could increase cooling significantly, as well as remove the need for an alternator to charge your battery, as you could hook these up in line, increasing engine output power, lowering heat, and increasing efficiency, as you be recycling the heat, instead of simply dispersing it into the atmosphere. I can't wait until this technology nears perfection.
*No SVX at the moment...* 1987 Winnebago Elandan 35' 2001 Yamaha Roadstar 1600 2004 Ford Excursion Eddie Bauer, 6.0litre Power Stroke Diesel - Daily Driver. Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, scotch in one hand, body thoroughly used up, totally worn out and screaming HOOOOYA !!!!! |
Thanks for posting it. This is the first that I heard of it.
It's very interesting
Larry III & The Beautiful Naviguesser '19 Tungsten Pearl Outback 3.6R Ltd...."AISHA" '08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU" '07 Gray Diamond Pearl Outback XT Ltd..."AH SO" '05 White Pearl & Silver BAJA Turbo..."AH HA" '97 Bordeaux Pearl SVX LSi..."SUBYDOO" '94 White Pearl SVX LSi..."PEARLY" '92 White Pearl SVX LSL w/touring pkg..."SVXY" '92 Teal SVX LSL w/touring pkg..."ALCYONE" '96 Polo Green LSi ... "MIDORI" '00 Black Dodge VIPER RT-10... "VINNIE" Engineers do it with precision. English teachers are novel lovers. Home: larrysingeriii@comcast.net SVX FEVER, CATCH IT AT A MEET NEAR YOU !! |
Strange
Strange that this is a 2001 article and reported research result and no current earth shattering news. Maybe it is quietly being used and is now old news.
Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE |
I actually think I remember hearing something about this concept from a WW2 book about the Nazis "crazy" schemes to limit the use of foreign resources for their war machine along with the ethanol powered vehicles and wood fired vehicles.
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
This is only an incremental imporovement on an existing technology. Soviet satellites used a similar technology to generate electricity. Unfortunately, this technology does not overcome the basic limitation of conversion of heat to electricity known as Carnot's law. It all has to do with entropy and the second law of thermodynamics. Electricity is work and work is organized energy. Heat is disorganized energy and only achieves order when there is an orderly flow of heat from a hot place to a cold place. The amount of order that can be harvested from this heat flow is a function of the temperature difference between the hot place and the cold place. The equation is as follows:
Max Theoretical Eficiency = (1 - ( Temp of Cold Place / Temp of Hot place)) These temperatures are absolute temperatures, so add 460 Deg to Fahrenheit and 273 Deg to Celsius. Note that the article said that 18% was achieved with a source temp of 200 to 300 DegC. Assume the heat is flowing from this hot place to the atmosphere at 30 DegC, the cold place. Using this formula, we get the following: Carnot Efficiency = (1- ((30+273) / (200 +273))) = 36% So, they're getting 18% when 36% is the theoretical maximum. Note also that 200 DegC isn't your run of the mill waste heat. A lot of waste heat is available at about 70 DegC, about 160 DegF, which will give you a Carnot efficiency of about 12%, and if the actual efficiency ratio above holds (which it probably doesn't), you would get about 6% efficiency. Probably not enough to go for. Which is why I always say to architects when they ask whether there's something that we can do with all the waste heat from the air conditioning that we send to cooling towers at 100 DegF. I tell then that they can put together a couple of quadrillion Btu's of that heat and $5 and they can get a cup of coffee at Starbucks.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
