Old 04-04-2007, 01:17 PM
davew833 davew833 is offline
Trans swap Q: '98 Legacy non-OB Wgn
So I've done a lot of searching and reading past threads on 4:11/4:44 tranny swaps and I'm STILL confused. I've got a chance to pick up a cheap 4EAT and rear diff. from a '98 Legacy (NON-outback, NON-gt) 4WD wagon with about 150k miles. Probably a 2.2, but the engine was gone so I'm not sure.
First question- will the tranny fit my '92 SVX? I understand there was a change in '98, something about a spin-on filter?
Next question: what is the gearing for this tranny?
Third question: is the diff correct?
Finally, do I use the Legacy TC or the SVX TC? The current tranny in my SVX works in all gears, it just has a delay engaging, so I don't think my SVX TC's full of "junk"
In the same yard is a '98 Impreza OB sport, which understand has a smaller differential. Would this be a better choice. Where could I get a matching diff?
Thanks for any help-
davew833@yahoo.com
Former 6-time SVX owner
Old 04-04-2007, 03:25 PM
Nomake Wan's Avatar
Retired
I would guess that the "delay engaging" is the ECU (is this on your '92 or your '95?) and not your tranny, so the tranny should be in good shape.
Best of luck with the swap.
Old 04-04-2007, 03:47 PM
svxxx26's Avatar
svxxx26 svxxx26 is offline
Headed to Texas...
Originally Posted by davew833
So I've done a lot of searching and reading past threads on 4:11/4:44 tranny swaps and I'm STILL confused. I've got a chance to pick up a cheap 4EAT and rear diff. from a '98 Legacy (NON-outback) 4WD wagon with about 150k miles.
I will answer as far as I know - there are many experts here that can elaborate more and verify what I've posted.
Some '98 trannies did have the spin-on filter. If yours does, avoid it.
I am assuming this Legacy is a Legacy GT with the 2.5 engine? The Legacy GT and the Outback are what comes with the 4.44s.
Not sure what you mean by "is the diff correct?" Presumably you will be taking the diff from the same donor car which has 4.44s.
I believe you can keep the SVX TC if it's OK. Again, verify this.
Be aware that there are many possible causes for the "delay engaging".
Jerry
2005 Baja Turbo
2008 Ford Crown Victoria Police Interceptor
jnj7707@yahoo.com
Old 04-04-2007, 07:02 PM
My search of other threads suggests the tranny delay on my '92 I experience (a few seconds before it engages in "D" or "R", but no slipping at higher RPMs) is a result of the pump gasket going bad and causing a decrease in line pressure at idle. If there's something else I should check, it would be great to know about it before I do a swap.
davew833@yahoo.com
Old 04-04-2007, 07:11 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Spin on filter = no go
You'll use the SVX's TCU
Use the "Search" feature on the network to check on compatibility info. SVXFiles did a post a while back that listed all of the years/models that work. As far as the rear diff goes, you'll need to modify the 4.44 diff to accept the LSD out of the SVX's rear. Again, use the "Search" feature for info on the mod (SVXFiles rules again )
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 04-04-2007, 08:27 PM
svxxx26's Avatar
Headed to Texas...
-Bill
SVXfiles is definitely a 4.44 guru
Jerry
2005 Baja Turbo
jnj7707@yahoo.com
Old 04-05-2007, 06:20 AM
Nomake Wan's Avatar
Retired
Has the crush mod been done to the ECU on that '92?
Old 04-05-2007, 08:20 AM
A standard Legacy Tranny will be 4.11's, but as long as it does NOT have a spin on filter on the side of th etranny, and you get the rear diff out of the same car, you're golden.
The SVX TCU will be fine.
