Old 05-22-2006, 01:31 PM
Temp Gauge Sending Unit location
Where is the Temp Gauge sending unit located at...should be a one wire sender....
Just want an ideal where to start looking...
Old 05-22-2006, 01:44 PM
Speedklix's Avatar
Locker Link Solution
I think both sensors are on the water pipe under the intake on the driver side (the end closest to the firewall). The inboard (smaller) one should be for the gauge.
...you'll have to push the hoses over to see it.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 05-22-2006, 01:54 PM
Thanks,
That'll narrow my search down when I get to it.....
You still coming to the Dragon?
Old 05-22-2006, 02:09 PM
Speedklix's Avatar
Oh yeah I'm coming.
If DHL ever decides to drive my parts over from their sort facility... I'll probably be set to bring the SVX.
There is always another subie I can bring though if the svx doesn't get back on the road in time.
-Mike
[SIGPIC][/SIGPIC]
