Old 05-20-2006, 04:10 PM
curly2k3's Avatar
curly2k3 curly2k3 is offline
Own'eded
Send a message via AIM to curly2k3 Send a message via MSN to curly2k3
Any Ideas?
Where the hell can i get a wire into cabin of the car!?!?!? This is getting really fusterating! I am trying to put on my new driving lights and can't find a place to run the wire into the cabin thru, I need to bring it in there for an on/off switch but dang! also, where do you think I should ground it on the inside?
Thanks for the help on my dumb questions.
98 Impreza Wago-O-Doom & Datsun Roadsters
Old 05-20-2006, 05:28 PM
Manarius's Avatar
Manarius Manarius is offline
I don't know if the SVX is the same, but my Legacy has a rubber plug near the brake pedal which easily pops out. I slit that, threaded my wire through and I was good to go.
-Jason
-Obi Wan Kenobi
Old 05-20-2006, 07:36 PM
curly2k3's Avatar
Own'eded
egh... I gave up on trying to find a plug or rubber gromit to get it thru that would still reach the switch, so I just brought it thru the rubber piece under the hood and between the fender and body... worked alright, looks like **** when the doors open, but its good enough for now.
Old 05-21-2006, 08:18 AM
nysvx10 nysvx10 is offline
When I did my stereo I brought the wires through the AC hole/grommet on the passenger side and it came in under the glove compartment.
Old 05-21-2006, 08:31 AM
curly2k3's Avatar
Own'eded
see, and I didnt have that kind of length, I needed it on the driver's side and close to the dash... no biggy
Old 05-21-2006, 09:26 AM
Manarius's Avatar
You didn't tap the battery for both positive and negative power did you? This will be the death of you if you forget to turn them off. I wired my positive lead into the fusebox inside the car and I don't ever have to worry about leaving the lights on.
-Jason
-Obi Wan Kenobi
Old 05-21-2006, 09:31 AM
curly2k3's Avatar
Own'eded
no, positive terminal only, 3 ways switch with a neg connection thru ground only when the switch is on
Old 05-21-2006, 06:34 PM
19svx94 19svx94 is offline
Send a message via AIM to 19svx94
there is a rubber gromet that goes right next to the brake booster for the tranny wiring harness, it is easy and clean to use that.
Old 05-21-2006, 06:48 PM
curly2k3's Avatar
Own'eded
I think I will use that once I start to install my new gauges when they come
