Old 05-16-2006, 04:50 PM
crimsonnblue
road noise from the rear
when ever I get up to speeds above 35 i hear a loud, almost like tire noise from the rear of the car, both sides.
Ive heard several suggestions but wanted to ask for advice before I got it looked at. I was told it could be the wheel bearings, but it doesnt grind and you cant hear it at low speeds so i didnt think that was it. I was also told it was just normal tire noise, but its gotten louder over time it seemed. Any suggestions would be appreciated.
Note: Steering wheel does not shake. and no abnormal wear on tires.
thanx in advance
Old 05-16-2006, 05:00 PM
If it's only the rear you could rotate the tires to see if the sound moves to the front.
Tire noise varies depending on road surface. bearing noise stays the same.
Old 05-16-2006, 11:34 PM
nipper nipper is offline
i would suspect wheel bearings. Sooby wheel bearings seem to start making noises at high speeds, then slowly gets worse. Wouldnt hope to get the car in the air and check them.
Another thing to check is to see if your tries are badly cupped, as this would cause it too.
nipper
Old 05-17-2006, 06:00 AM
dcarrb dcarrb is offline
Rear wheel bearings get my vote, too.
dcb
Old 05-17-2006, 06:49 PM
This is an excellent suggestion. I am not dumb when it comes to cars, but because of the carry on here relating to wheel bearings, I was suspicious regarding mine. After I put on a new set of tyres my anguish ceased.
Old 05-17-2006, 11:53 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
thanx in advance
what type of tires are you running? it could be the wheel bearings but its best to rule out all other posiblities first
- John
