Old 05-15-2006, 11:25 PM
q2driver q2driver is offline
JDM Engine
Hello,
I did a quick search and found no answer for my question. What are the differences between the JDM EG 33 and the US spec engine? I emailed a question to the sellers and they say the engines are interchangable. They use the same ECU and Wiring harness. Any more knowledge would be wonderfull. Thanks...
Old 05-15-2006, 11:53 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
im not sure on the SVX but you might need to swap out the intakes... i know some JDM's are carb and fuel injection in the US
- John
Old 05-15-2006, 11:55 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
A CARB on a SVX?! That would be strange to see.
Old 05-16-2006, 12:17 AM
Suby Fan's Avatar
sorry i ment on other engines... i dont think a dhoc engine with a carb exists... for example geo metro engines are carb every where elce in the world
- John
Old 05-16-2006, 12:19 AM
Carb AND fuel injection is something I would wish to study. I have been assuming that my JDM has none of this. But hold it while I have a look under the bonnet(hood).
Sorry to make a joke out of what is probably an unfortunate mistake and no offence intended.
Old 05-18-2006, 02:01 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
All SVX engines are the same (except for the JDM twin-turbo police special )
The ECU programming is different, presumably this is to accomodate regional fuel differences. It is rumoured that the JDM cars are optimised for the 100+ octane fuel that they get in Japan. My JDM cars definitely run much better on 98-99 than the standard 95 we get here in the UK.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 05-18-2006, 05:12 AM
Engines are the same, the only differences are in the ECU. People like Silverspear have Open loop ECU's which do not function off emission standards and run on a basis of optimal performance for regions allowing it
Old 05-18-2006, 01:25 PM
intelisevil's Avatar
<<<Alcyone
What could that do for those of us in the US that don't have to worry about smog checks?
Dan
Old 05-18-2006, 01:29 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Very true. His SVX doesn't have any O2 sensors...
2006 Steel Gray WRX TR (sold)
Old 05-19-2006, 11:31 AM
floatingkiwi's Avatar
floatingkiwi floatingkiwi is offline
A flight-less flyer
Send a message via Yahoo to floatingkiwi
Immmmmm, interesting, wonder if ECUTune could bring out something to take advantage of that particular ECU (and it's programming).
The JDM ECU is definitely different. Note the incompatibility of LAN's chip, for example.
'92 JDM (E) Burgandy/Black 100Km
Just Crusin'
Old 05-19-2006, 10:28 PM
I do not see a big enough gain to buy and ship an ECU from the middle east. not only will sourcing one be a HUGE pain in the arse but it will cost more than it is worth. The Stage 2v5 ECUtune would probobly be more worth your while. Additionally I am not sure how well that ECU will work with the USDM wiring setup and whatnot.
Old 05-19-2006, 10:35 PM
Speedklix's Avatar
Locker Link Solution
By the way...
There are those two dragsters that have carb feed eg33's in em.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 05-20-2006, 12:07 AM
Nemesis Destiny's Avatar
Nemesis Destiny Nemesis Destiny is offline
6MT STi-ified, now with R180!
Send a message via ICQ to Nemesis Destiny Send a message via MSN to Nemesis Destiny
Also, according to a recent or semi-recent post I read from LAN, the USDM ECU runs the EG33 quite well with the O2 sensors unplugged. If I recall what he said correctly, the ECU ignores the lack of input from the O2 sensors. Apparently the engine runs even better without them.
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto.
1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong!
2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver.
1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver!
2007 Honda CR-V, some awful shade of light green *yawn*
1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED.
1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust*
Old 05-20-2006, 12:42 AM
Are you sure about that? I mean there is no way for them to have used anything but a distributorless ignition so why change from Multiport Fuel Injection and downgrade to Carburation? Just doesn't make any sense
Old 05-20-2006, 07:44 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Carburated
Yes, the Aragona cars were carbureted. You can even see it in the pictures of them. Actually 2 carburetors. I don't think he was running gasoline though.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
