Old 05-02-2006, 12:57 PM
Dessertrunner's Avatar
High fuel usage
My cars has suddenly started using a lot of fuel, a month ago it was brillant and now I get 200 k less per tank. Any ideas.
Tony
Old 05-02-2006, 03:52 PM
Pick it up in the air and see if your brakes are dragging.
Or binding in your driveshaft or carrier bearing.
Old 05-02-2006, 04:33 PM
Manarius's Avatar
Manarius Manarius is offline
Check O2 sensor(s), spark plugs, and coils. If your car is running rich or the gas isn't getting burned, it will use more.
-Jason
-Obi Wan Kenobi
Old 05-03-2006, 01:33 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Is the car running rich and hot?
I had all this problem with my Legacy recently. It was a bad connection on the temperature sensor. As a result the ECU was giving way too much fuel and the cooling fan never cut in.
Phil.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 05-03-2006, 04:03 AM
how do I tell if it is running rich.
Old 05-03-2006, 04:41 AM
Manarius's Avatar
Most people say they can tell by smell. I would think you can smell it, but I'm not sure (I can't really smell that well).
-Jason
-Obi Wan Kenobi
Old 05-03-2006, 04:48 AM
That makes sense as I some times think I can smell a funny smell like oil on the exhaust but not the same. I was going to disconnect the O2 and see what happens to the fuel consumption. I have some new ones on the way as well.
Old 05-03-2006, 04:54 AM
b3lha's Avatar
Phil & Belha
Usually black soot on exhaust and/or plugs. Slightly higher than normal idle. Slight smell of petrol from exhaust.
Like an old car with the choke out.
Old 05-03-2006, 07:19 AM
Antigenus's Avatar
Antigenus Antigenus is offline
Send a message via AIM to Antigenus
Exclamation e
mine runs between 800-1000 rpms on idle, usually higher if i just started it cold. My exhaust has some smalls holes in it, and im sure the o2 sensors are bad from it. The smell of petrol is really evident at times. Sounds like I have this problem too. My gas mileage has always be sh*tty.
Matt - Akron, OH
And then what???
