Info on sound of Knock Sensor (link)
I found this link which is very interesting.
http://users.wpi.edu/~mark944/nested...knockstuff.htm This has a MP3 of a knock sensor signal.
1992 (JDM) CXD Ebony Pearl 90K km written off hail damage 1996 (CDN) Lsi, Polo Green, 296,000 km 2009 Legacy Spec B |
Bosch Knock Sensor vs OEM.
Anyone have any experince with a Bosch knock sensor. I need to replace mine and was quoted $167 CDN per sensor at local dealership. I have found a source online in Canada for a Bosch Sensor for the SVX at $58!!!
order it they are pretty much the same thing go with the after market.. the wiring harnesses are the same... if they use the same knock sensor as a subaru legacy the one for my moms was cheeper then 58 bucks
They are less than USD$50 each from Auburn Subaru (formerly 1stsubaruparts.com)
Part# 22060AA031
I've been experiencing a maddening engine shudder for the past several weeks, and finally the car threw a CE that my Knock Sensor 2 was bad. So decided to change it, Knock Sensor 1, the fuel filter, and the PCV valve. I removed the alternator, and went to work. It was fairly easy to replace the PCV valve, and fuel filter, but the Knock Sensor 1 was a bear, and knock Sensor 2 was IMPOSSIBLE to reach...even when I tried to move the AC pump out of the way. For the life of me, I can't figure out how anyone has hands small enough to reach in there from the front. So I guess I've got to remove the intake collector, huh?
And by the way, I got all my parts from the Subaru dealer, and the knock sensors were $48 apiece. Maybe since I have to remove the collector anyhow, I'll install phenolic resin spacers from Outlaw Engineering while I'm at it. Now if I could just figure out what's making my engine stumble... Cappy
Cappy '94 LSi Barcelona Red 158,000 miles '92 LS-L Dark Teal 47,000 miles '95 Olds Acheiva 104,000 miles '85 Audi 4000 135,000 miles '87 Supra 129,000 miles - 2nd JDM engine |
Thread Tools | |
Display Modes | |
