Old 04-18-2006, 12:50 PM
Coolant Temp Sensor???
There's been a slight issue lately with the racer. When the engine is cold, it starts fine. And, when the engine is hot, it starts fine. But when it is warm, like after sitting for 20-30 minutes it cranks and cranks but won't start, smells real rich.
We're thinking it's the Coolant Temp Sensor?? Would the SSM verify this??? Is anyone bringing either of their two SSM's to Reading ( Tom???)
Old 04-18-2006, 12:56 PM
I'll bring an extra temp sensor 4 you guys!!!
Old 04-18-2006, 01:07 PM
My experience showed the sensor to only affect cold starts.
Any codes after the cranking? Possibly crank/cam sensor?
Old 04-18-2006, 02:11 PM
Manarius's Avatar
Manarius Manarius is offline
Coolant Temp Sensor almost always affects warm engines.
-Jason
-Obi Wan Kenobi
Old 04-18-2006, 02:25 PM
Is that from personal SVX experience?
Old 04-18-2006, 04:26 PM
Manarius's Avatar
That's the way it is with Subaru engines. You start the car cold, and it fires right up. You drive it and head into MCD's for a Burger to go (or you eat in). You walk out and the thing starts after cranking it for 5-10 seconds (or longer). Plus, coolant temp sensors are the cheapest and easiest to replace out the the three (crank/cam are more than a CTS as I recall; CTS is only $20). When Legacy's do what is described, 9/10 times it's a CTS. Crank/Cam usually affect cold starts (the ECU doesn't know where the crank is at and misfires).
-Jason
-Obi Wan Kenobi
Old 04-18-2006, 04:28 PM
he is right. The hard start when warm is usually a temp sensor.
Old 04-19-2006, 06:12 AM
dcarrb dcarrb is offline
Curiously, my brief episode of hard-starting happened only with a cold engine, at around 32F. Replacing the ECU temp sensor solved the problem... or it vanished coincidentally.
dcb
Old 04-19-2006, 11:49 AM
works both ways. The ECU doesn't know the coolant temp and doesn't know what is going on so it goes to default which is not always optimal. At least thats what I think
Old 04-19-2006, 12:48 PM
When the ECU doesn't know the engine temp it goes into limp mode (rad fans on, etc)
Old 04-19-2006, 01:54 PM
or as I like to call it, default. Same thing really, just messes with the fuel and timing tables and can cause hard starts
Old 04-19-2006, 07:14 PM
...limp mode (rad fans on, etc)
The fans in the racer go on when we flick that little switch
Old 04-19-2006, 07:17 PM
well I will try and remember it along with the million other things I need to bring to reading
