Old 02-03-2006, 09:25 AM
daddy
Decided to pass this one. If anyone intersted PM me for seller's email.
Old 02-03-2006, 09:48 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Originally Posted by DarknessofDeath
try to be very picky about choosing an SVX.
i bought one half a year ago and have spent 10 grand fixing the thing already.
i am sure to spend another 5 at least to make it some what "decent" running condition for me
10 Grand??!!! What the heck needed to be done to it to cost that much? I don't believe that...what did you do get 3 new transmissions put in that beast?
That car in the pictures definately will cost 2-3k just to get it looking and operating good. Silverspear is right. I bought my car in fairly better shape, but cost me nearly 2000 just to fix all oil leeks, abs, exhaust, and some electrical odds and ends.
1995 Subaru Svx L / AWD
Old 02-03-2006, 03:26 PM
DarknessofDeath's Avatar
Inhabitant of Darkness
costs on parts alone
ok.
here is as much of the bills that i have..missing a few though.
car itself paid 3000$ but that's not included in the 10 grand
parts -in order of replacement.
retrofit kit - 28$
a/c compressor - 735$
receiver drier - 96$
seals x4 -16 $
2 lbs of freon 134A - 40$
wiper blade x3 - 20 $
right side wiper arm - 67$
left side wiper arm - 55$
rear wiper arm - 45$
lower ball joint -134$
front wheel bearing -104$
oil seals x2 - 45 $
catalytic converter -720$
front gasket - 12$
rear gasket - 24$
fuel pump - 636$
rear view mirror - 68$
fuel filter - 51$
interstate battery - 110$
altenator - 265$
timing belt - 166$
water pump - 128$
upper rad hose - 29$
lower rad hose - 26$
thermostat - 13$
seal - 3$
hose clamps x4 - 5 $
2 lbs refrigerant 134A - 60$
right and left front calipers - 233$
bulb and socket x6 - 60$
bearing - 104$
seals x2 - 45$
link rods x2 -180$
nuts x4 - 16$
ecutune 1v4 - 219US$
small car shift kit - 45US$
drilled slotted rotors - 140US$
these are prices rounded down for parts put on the car. plus labour charges on top of that and fluids used
plus taxes @ 15% . it's in canadian dollars except the last few
i picked a bad car to buy and i''m paying for it. i like the car so....it sucks to be me
still need a/c condensor, exhaust has to be replaced, paint job....tranny is ...i cant' manage to adjust the brake band...that should be the problem with that..rear bearings...could use a compustar(to unlock the doors)
i dont know....
if you dont believe...
then dont
Old 02-03-2006, 03:47 PM
and i would also like to replace trunk light unit (the unit that lights the inside of the trunk- mine is having bad connections) and sunroof weatherstripping.
haven't done external filter or tranny cooler......
f ck
Old 02-03-2006, 10:07 PM
Speedklix's Avatar
Locker Link Solution
f ck
If I ever kept track of all the bills, I'd probably be upset too!
Ignorance is bliss!
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 02-04-2006, 11:37 AM
Thats what I paid for mine in August!!!!
Same color, same everything. 30k less miles, but the body was in about that shape. Now I have a couple more.
Good Luck. and get out of that Civic! lol.
