Old 01-14-2005, 11:09 AM
mhl0125 mhl0125 is offline
Send a message via AIM to mhl0125 Send a message via Yahoo to mhl0125
Automatic climate control problem
I just had the transmission rebuilt and the valve cover gaskets and seals replaced as well as the spark plugs changed. Now when I put on the Auto climate control, nothing happens. If I use the manual controls, everything works. Do you think something got messed up when the work was being done and what could it be. I am not getting an error codes.
Michael
1994 Barcelona Red SVX-LSI
Two-owner:169K
1995 Emerald Green SVX L AWD
#80 - Custom intake w/cone filter
99K with killer stereo system
2002 Acura MDX-Touring Edition w/navigation
2008 Toyota Prius
1987 Mercedes Benz 560SL
Old 01-14-2005, 12:20 PM
Mr. Pockets's Avatar
Moderator
Are you giving it time? I see that you're in a colder state, and the car won't give you any heat until it has heat to give.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 01-14-2005, 12:59 PM
Does your A/C work?
If it's working in manual and not auto that could be an indication. Try running the diags.
Old 01-14-2005, 03:06 PM
I am giving the cr plenty of time to warm up. The heat and AC work in manual modes. They don't come on even when I take it down to 65 degrees or up to 85 degrees. What diagnostics can I run?
Michael
Two-owner:169K
2008 Toyota Prius
Old 01-14-2005, 03:17 PM
Go to http://svx-iw.com and click on codes.
