Old 12-20-2004, 06:10 AM
mhl0125 mhl0125 is offline
Send a message via AIM to mhl0125 Send a message via Yahoo to mhl0125
Transmission jerk in "Park"
When I put the car into "park" and turn off the ignition, the car jerks slightly backward. The car is on a level surface. Has anyone ever had this experience or know what it might be?
Michael
1994 Barcelona Red SVX-LSI
Two-owner:169K
1995 Emerald Green SVX L AWD
#80 - Custom intake w/cone filter
99K with killer stereo system
2002 Acura MDX-Touring Edition w/navigation
2008 Toyota Prius
1987 Mercedes Benz 560SL
Old 12-20-2004, 07:35 AM
n00b on demand's Avatar
The car should lurch a little forward if anything.
Old 12-20-2004, 07:54 AM
Re: Transmission jerk in "Park"
do you park your car on P ? only ? you should park your car on the handbrake, take out your foot from the foot brake to let it settle on the hand brake and then put P.
You know all the Range Rovers (95-2000) are having their transmisson broken because of this way in parking... so BEWARE YOUR TRANNY !!!
Old 12-20-2004, 02:05 PM
pavanbabut's Avatar
Re: Re: Transmission jerk in "Park"
I agree.... it is the best way to park ur car on handbrake... i always do in tht way only... and also it helps to keep ur tranny safe....
Old 12-20-2004, 06:37 PM
THAWA
this goes the same for manuals. Brake first, then use the tranny as a secondary measure.
Old 12-22-2004, 01:49 PM
red95svx
Yep. Let the brake do all the work, with the tranny as a back-up.
A little known fact: the harder you press on the brake pedal before you set the parking brake, the stronger the parking brake holds.
Old 12-22-2004, 06:17 PM
Weebitob Weebitob is offline
The Kind of Casual SVXer
Send a message via AIM to Weebitob
Thanks, one other thing I have to think about aside from allmost always gradually bringing the car to a stop.
Just kidding, like gradually stopping using handbrake instead of park is probably healthier for most cars and trucks. And any procedure to ensure longitivty for any other car I should do for my SVX, well most.
Old 12-22-2004, 06:59 PM
Re: Re: Re: Transmission jerk in "Park"
Wow! I never knew that one. I gotta start doin that from now on when im on hills.
Old 12-23-2004, 09:21 PM
drivemusicnow's Avatar
Poor College Racer
How can this possibly be true? the brakes are a hydraulicaly powered disc system that is COMPLETELY seperate from the drum brake parking brake system that is in the rear discs, that is operated by a cable.?!???
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 12-23-2004, 09:54 PM
Mr. Pockets's Avatar
Moderator
I'm trying to imagine what might cause this. Could you be a little more specific and explain step by step what you do and when the car does what it does? Are there any noises associated with the jerk? Does it matter whther you're parked on a level or angled surface?
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 12-23-2004, 10:34 PM
Poor College Racer
also does it depend on if you put it into park really quickly, or go through both neutral and reverse and then park?
I'm not sure but on the 4eat, but it would seem that maybe one of the reverse gear clutches is getting a slight jolt of power.. maybe an electrical/short issue??? (speaking from knowledge not wholly related to cars... )
Greg
Old 12-24-2004, 06:40 AM
It doesn't matter what the slope of the surface is that I am on. I stop the car with the foot brake, put the gear selector into park, and turn off the ignition. As soon as I turn it off, the car jolts backward about two inches. This is without using the hand parking break. Of course, if you put on the parking brake first, it prevents this. I am concerned there is a problem in the transmission.
Michael
Two-owner:169K
2008 Toyota Prius
Old 12-24-2004, 07:20 AM
Moderator
But is it 'trying' to jerk backwards? I mean, the parking brake is holding the car, but is there an obvious jerk from the tranny anyway?
Does your 'power' light blink when you start the car? That would indicate an electrical fault in the tranny.
Thanks for being more specific - but at the same time I wish you hadn't. It's just really weird and I haven't a clue right now what would cause this when you shut the ignition off.
2005 Outback
END OF LINE
Old 12-24-2004, 10:07 AM
It does jerk anyway and yes I am getting an error code of 24 whicj is Duty Solenoid C in the tranny. I am going to have it replaced next week and see what happens. The part is $70 and I have no idea on the labor.
Michael
Two-owner:169K
2008 Toyota Prius
Old 12-24-2004, 12:32 PM
thundering02's Avatar
Giong back to the beaters...
Re: Re: Re: Re: Transmission jerk in "Park"
THANK YOU and weve gone over this(not the trans jerk) in another thread already....
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
