Old 12-27-2004, 04:49 PM
BigBlueSVX's Avatar
BigBlueSVX BigBlueSVX is offline
Donate to the mod fund
Send a message via AIM to BigBlueSVX
Finished!
I actually didn't finish the job until Christmas day, because I'm not that experienced and I worked on it on and off because there was no hurry to get it done. I was also slowed down by bolts that refused to move and the fact that there isn't much room for your hand under the intake manifold. I'm sure if I did it again I could do it much quicker. Rufus' write-up was a big help, and by following his instructions I was able to get the job done.
Here is a quick overview of what I did:
1. Removed belt cover
2. Removed belts
3. Removed alternator
4. Removed engine lift bracket and moved the compressor out of the way (see pics)
5. Removed and replaced both sensors.
I have now replaced both oxygen and knock sensors with nothing but help from this site. Thanks guys.
Here is a pic of how I got the compressor out of the way. It was crude but it worked:
1994 blue FWD Subaru SVX L with 86k and the original tranny *SOLD*
My Cardomain page
Now part of the DSM crowd: 1990 Mitsubishi Eclipse GSX
Old 12-27-2004, 04:52 PM
BigBlueSVX's Avatar
A pic of the left knock sensor hole:
My Cardomain page
Old 12-27-2004, 04:53 PM
BigBlueSVX's Avatar
A pic of the right knock sensor hole:
My Cardomain page
Old 12-27-2004, 05:00 PM
BigBlueSVX's Avatar
Here is one of the alternator and the engine lift bracket after they have been removed:
My Cardomain page
Old 12-27-2004, 05:03 PM
BigBlueSVX's Avatar
Lastly, a pic of the old knock sensors:
My Cardomain page
Old 12-27-2004, 06:33 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Blue,
Great pics! Have you been able to put an ohm meter on the sensors you removed to see which one (or both) were bad?
Did you use a 12mm wrench or did you come in with a socket?
Please post back once you've had a chance to drive the car for a while -- I'm very curious to see how performance has been improved.
Thanks again for posting the pics!
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-28-2004, 12:26 AM
BigBlueSVX's Avatar
Originally posted by SVXRide
Blue,
-Bill
I haven't put an ohm meter to them so no, I don't know which one is bad. I used a 12mm wrench for the knock sensors because there wasn't enough space to use a socket. I've only driven for two days now, but it is definitely more powerful. I'll figure out my mpg the next time I go through a full tank of gas.
My Cardomain page
Old 12-28-2004, 08:15 AM
Thanks for the pics BigBlue
I have to do this job soon myself soon. Started throwing a code 28 just before Christmas.
Old 12-28-2004, 08:47 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
Great pics! Should make my job a little easier...Thanks!
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 12-28-2004, 12:16 PM
BigBlueSVX's Avatar
No problem. Good luck everyone.
My Cardomain page
Old 01-11-2005, 09:49 AM
SVXRide's Avatar
Blue,
Your "old" sensors look new compared to the passenger's side one I replaced last night! Its case was cracked all the way through almost all the way around. Weirdly enough, it still had a resistance measurement within Subaru's spec ("approximately 560k ohms"). I really have to question whether it was working correctly under dynamic loads (i.e. at other than idle....)
-Bill
Old 01-11-2005, 07:43 PM
BigBlueSVX's Avatar
Blue,
-Bill
Interesting. How did the install go? No more codes? Sadly I got another code the other day, but I haven't checked it yet. It came on and went off pretty quick, I have a feeling its for the EGR because thats what I've gotten before.
Collin, how did your install go? Are you still getting code 56 for the EGR system?
My Cardomain page
Old 01-11-2005, 08:29 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
anyone interested: i have a good knocksensor if you need one!
phil
~Phil
Old 01-11-2005, 09:06 PM
SVXRide's Avatar
The install wasn't all that bad, once I removed the alternator. Weirdly enough, I wasn't getting a knock sensor code...the engine performance just wasn't "right" and I had a sneaky thought that the knock sensors were the originals (and I was right!).
This all typed...I still have the driver's side sensor to replace....going to see if I can do it without removing the engine lift bracket..
-Bill
Old 01-13-2005, 09:49 PM
SVXRide's Avatar
Look ma, sensor guts!
Finished off the driver's side sensor this evening and actually did not have to remove the engine lift bracket. I was able to do both sensors after just removing the alternator. I've got a bunch of pics in my locker of the removal and installation. A small part "grapper" - little tool with 4 "fingers" at the end was invaluable on the driver's side sensor. I also found that if you clip the "wings" that are on the female connector for the driver's side sensor it is much, much easier to thread it back to the male connector under the throttle body.
Note: while my car was not throwing codes for either knock sensors and they both checked out within spec (~560k ohms) when I put my digital multimeter on them, the case on both sensors was cracked all the way through - the picture above is of the passenger side sensor (next to the new sensor). Guess this is what happens after 13 years and 186k+ miles.
Now we just have to see how she runs!
-Bill
