Old 11-27-2004, 08:34 PM
HighwayUFO's Avatar
HighwayUFO HighwayUFO is offline
After 200, it's all the same.
I've got some weird Front end noise
Was driving downtown last night and took a left turn when all the sudden the car started vibrating and making a rapid clicking noise then a POP then the rapid clicking noise again. It does it turning right and left.
I'm pretty sure its not my CV axles because i recently had them replaced. Does anyone else know what it could be? Any and all suggestions are welcome.
The member formerly known as Civic_Slayer
1992 "Robins egg blue" SVX Originally Claret 147k- CURRENT
1992 Pearly 187K and climbing (11-91) #964 *retired
1992 Pearl SVX 122500 miles #86 FASTAR THAN THE OLD ONE.*SOLD
Everytime I get into my car, it always reminds me that it has POWER
Old 11-27-2004, 08:41 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
If it shakes when you turn both left or right, my guess is that it could be your ball joints gone bad...
-Chike
2006 Steel Gray WRX TR (sold)
Old 11-28-2004, 06:46 PM
n00b on demand's Avatar
my front wheels shake when im driving at high speeds....not shake out of control but u can veel vibrations...somedays are worse than others. I know i have a bent rim....but could it be my ball joints? ...I dont get any clicking or popping when i turn. I had my right front axle replaced in may. Could bad bushings be the cause of this as well?
Old 11-28-2004, 06:51 PM
No shaking when turning either....one thing though....when i brake at a very high speed...lets say 65 or above the brake pedal will pulsate a tiny bit but the steering wheel will shake a little bit. I was told i have grooves in my rotors. I was told that back in october. Funny how i never felt anything wrong with my brakes untill i took it into that damn shop and felt the vibration and pulsation afterwards .
Old 12-06-2004, 01:18 PM
Could it possibly be the front diff?
Old 12-06-2004, 01:54 PM
Talking to the slayer or me?
Old 12-06-2004, 02:41 PM
dcarrb dcarrb is offline
So soon after half-shaft replacement, I'd be concerned the shop didn't get something right in the reassembly. That, or one of the CV joints was junk and is already failing.
It's been decades since I've had to replace a ball joint, but they usually wear very gradually and cause slowly-worsening front end play. Not the sort of thing to be noisy (unless it fails... now, that would be sudden and noisy). Jack-up a front wheel, grab the tire at the top and push-pull to see if there's any give.
dcb
Old 12-06-2004, 03:25 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
Could be a front bearing.
I had a front bearing failure. Thought it was cv's, but still had a problem after replacement. Finally, when it got so bad that the wheel almost fell off, I could tell it was bearings. Really didn't seem like bearings at all.
Swapped knuckle/spindle assemblies with a used one and fixed it for under $100.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 12-08-2004, 01:00 PM
That was directed toward C.S.
