Old 12-28-2003, 05:13 PM
svxsubaru1's Avatar
Question Seat will not move.
I am doing a 5spd swap and was going to go after the pedal assembley today, but the driver side seat will not move at all. The battery has been dead, but i put a good battery in it, all the lights lit up the radio worked, but the seat will not move. I have taken the auto gear shifter assembley will that afect it, were is the power source for the seat. Also what fuse is it.
Thanks
Also my key is stuck in the ignition, can i take out someting to make it work sence the gear shifter for the auto is out.
Old 12-28-2003, 11:00 PM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
The connections for the seat motors are underneath the seat. You should just go ahead and remove the 5 14mm bolts and pull the hole thing and then you can check the connections.
As for the key, you need to jump two pins on the shifter connector. I can't remember which ones to jump. I believe there are only four and I just tried them all until it clicked. It something you will need to make permenant.
Old 12-30-2003, 03:45 PM
svxsubaru1's Avatar
I can get 3 of the bolts out that hold the seat but were are the other two, the seat is almost all the way back and I cant stick my down there to see were the bolts are. THANKS
Old 12-30-2003, 04:38 PM
Green1995SVX
This is sort of a dumb question, but did you check the fuses?
Mike
Old 12-31-2003, 09:20 PM
svxsubaru1's Avatar
Yes i want to check the fuse but what is it labled as on the fuse box, i cant find out. Does any one know? Thanks
