Old 12-20-2003, 05:34 PM
drivemusicnow's Avatar
Poor College Racer
oil dipstick pops out??
I know i saw something about this awhile back, but i can't seem to find it... what would cause the oil dipstick to pop out like half an inch? umm no leaking, no other problems really just that. (no CE light either)
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 12-20-2003, 05:41 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
PCV valve clogged? The bottom end is getting pressurized and popping the dipstick to release the pressure.
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-20-2003, 06:20 PM
really? i am having the same occurence.
Old 12-20-2003, 07:18 PM
lee lee is offline
it's either the PVC is clogged or the rubber o-ring around the dipstick isn't doing it's job anymore. I changed my PVC valve and still had the problem.
the o-ring path is easiest to try first. Cut off the old one using a razor knife and take it in with you to a hardware store - match it up and put it on the dipstick. I think it cost me 17 cents at my local Ace Hardware - just make sure to ask one of the old hands in there if the material can handle oil.
Old 12-20-2003, 10:26 PM
The size of the O ring is 8.8 X 1.9 mm. You can also get one at the local Suby dealership - part number 806908080 for about $1.00. I found that replacing the O ring usually fixes the problem. Good luck.
Old 12-21-2003, 03:23 PM
The PCV only vents the crankcase at idle or cruse. It is closed when the pedal is down, so the only way for the crankcase to vent then, is through the two pipes that run from the top of the cam covers, to the bottom of the air box, in front of the throttle body. These two pipes are connected together, through a passage that connects to the air delivery pipe on the right hand side of the throttle body, by a small elbow pipe.
There is probable a blockage in this area, where the elbow pipe connects to the cam cover pipe passages. Can gum up like the rest of this area.
Disconnect the two hoses off the cam covers, block one of them and blow into the other. It should be free to flow air, out the small elbow pipe.
Old 12-22-2003, 06:23 PM
foresvx foresvx is offline
Even more lazy...
I noticed mine doing that approx. a year ago, just for "grits & Shins" I decided to rotate the dipstick 180 degrees in the tube to see if that would keep it from popping out.
It worked...I guessed that after 10+years that the dipstick kinda formed to the contour of the tube & rotating it caused it to rest against the inside of the tube again with enough pressure to keep it from popping out.
May just be the SVX "Gods" messing with me again, but for a year or so now, no more pop-up problem.
