Old 01-04-2010, 06:18 PM
angrydan angrydan is offline
Sunroof Gasket -- This isn't right, right?
Dumb, quick question... I just got my car back from a body shop who fixed some cracking paint on my roof. Understandably, they had to remove the sunroof gasket to paint, but it looks to me like there is a piece of the gasket broken or missing?
Can someone just confirm for me that there shouldn't be that gap in the middle? And if so, what is SUPPOSED to be there? Its something I never took notice of... Thanks in advance!
-Dan
Dan Taney
1996 Subaru SVX LSi (Red)
2019 Subaru WRX LTD
Old 01-04-2010, 06:35 PM
**Ewie**'s Avatar
**Ewie** **Ewie** is offline
Aussie in enemy territory
Re: Sunroof Gasket -- This isn't right, right?
No gaps in mine at all....
Old 01-04-2010, 06:46 PM
Ok... thats what I thought. Thanks! Does anyone know if there is like some small piece that is supposed to join over the two ends of the gasket or anything? All I can guess is that either a piece of the gasket broke off or there was some coupler piece that they didn't reattach... any thoughts?
Dan Taney
2019 Subaru WRX LTD
Old 01-04-2010, 06:53 PM
MadMaxSvx's Avatar
MadMaxSvx MadMaxSvx is offline
Rubber is flexible, maybe they reattached the gasket not making enough tension so the rubber goes all around the sunroof line.
95´ Subaru SVX EURO
85' Mercedes 190 2.3-16
86' Mercedes 190E
70' Olds Toronado
98' Renault Chamade
82' Honda Prelude
79' Honda Accord awaiting restomod.
69' Mustang Hardtop
67' Jeep Ford Willys awaiting restoration.
67' IKA Torino Coupe
74' Renault Torino Coupe
Old 01-04-2010, 06:57 PM
gstape gstape is offline
When I had mine off to repaint my roof a couple years ago I ended up with a similar gap when I put it back together. I took it back off and stretched it a little and put it back on. Then the gap was mostly gone. There isn't anything else that goes in there.
Old 01-04-2010, 07:50 PM
Ok, thanks for everyone's input. I am just going to take the car back to the shop tomorrow and have them attempt to fix it. This way if anything gets damaged in the process, it won't be on me
Old 01-04-2010, 08:16 PM
Green1995SVX's Avatar
the seam in the rubber should be at the back of the sunroof, too. Not the front.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 01-04-2010, 09:29 PM
AyeJaye's Avatar
AyeJaye AyeJaye is offline
Mine has a gap and has never leaked in the time I've owned the car.
92 LS-L, Ebony Pearl, 160k miles, sitting in the hospital waiting room hoping for a miracle
06 Hyundai Sonata GLS, 77K miles
Old 01-04-2010, 09:50 PM
ZMan's Avatar
ZMan ZMan is offline
Yes, they can have a gap - it is designed so water can leak in, but there are four drain hoses - one in each corner - to let the water drain out.
Old 01-04-2010, 10:22 PM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
But if you can avoid it, wouldn't you not want the gap? And not have water leak in?
It should be pretty simple for them to fix it, might just have to stretch it a bit as gstape mentioned.
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 01-04-2010, 10:23 PM
There should be no gap.
My pearlie had a gap in the sunroof rubber (about 1/2") when I bought it. When I had the sunroof panel repainted, the shop took the molding off. When they reinstalled it, they also stretched in so that it actually overlapped at the ends. After they installed it the rubber was compressed at the ends and has never moved, maintaining a perfect seam with no gap. The same with my polo
Do this in warm weather or use a heat gun or hair dryer to soften the rubber a bit to make it more pliable.
Old 01-05-2010, 07:34 AM
ZMan's Avatar
Yes, it would look a little nicer without the gap.
I was saying that it doesn't matter if water gets beyond the sunroof [ i knew i shouldn't have used the word leak]
I had a clog in one of the drain tubes once, and after i cleared it i tested all 4 drain tubes by pouring GALLONS of water in each corner to make sure they were clear.
Not a drop of water got into the car - which is the way it's supposed to work.
So if it bothers you, then fix the gap, but if your drain tubes are clean, and you should make sure they are, it won't matter if water gets in there or not.
Old 01-05-2010, 02:09 PM
Thanks for everyone's input. The body shop was able to heat it up and stretch it to fix the gap. They also put the seam in the rear of the sunroof where it belongs!
Thanks again!!
Old 01-05-2010, 08:45 PM
BRADY's Avatar
BRADY BRADY is offline
SVX Addict
Send a message via MSN to BRADY Send a message via Skype™ to BRADY
Cool. Thanks for this. Mine has a gap at the rear of the sunroof. I have always wondered if this is right or not. I shall fix this now.
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com
Display Modes
