Old 08-09-2008, 02:29 PM
oneringer oneringer is offline
rear wheel wobbly
My right rear wheel is wobbling bad enough so that you can see it in the rear view mirror. Feels like it is ready to fall off.
I removed both rims yesterday, but can't really see, or feel, anything different between them.
I can't move the wheel with my hands when the car is sitting still, but as soon as you start to drive it, the symptom re-occurs.
I'm not at all familiar with this type of an axle. Could it be broken?
Old 08-09-2008, 02:50 PM
Re: rear wheel wobbly
The wheel may be bent. I've seen many that have no obvious damage, but when spun on a balancer wobble like mad. Are you running stock wheels or aftermarket? If it isn't the wheel you may have a warped hub. My final guess would be that your wheel bearing has completely disintigrated, but that would include amazing amounts of noise. Put the car up on jackstands, put it in neutral, and spin the wheel by hand to see what it does.
Stop driving the car in the meantime.
Old 08-09-2008, 02:53 PM
kwren's Avatar
kwren kwren is offline
a broken axle would not be in the equation, The bearing in the hub supports the whole thing, Could a bearing be worn that much??? Could be warped hub.
I had a front hub warped from a big hole on the road.
Good luck,
Keith
Old 08-09-2008, 02:55 PM
kwren's Avatar
my typing speed always gets me there in second place!
Good advice, Crazy person!
Keith
Old 08-09-2008, 03:13 PM
JLHollowX13's Avatar
JLHollowX13 JLHollowX13 is offline
Send a message via AIM to JLHollowX13
Good luck,
Keith
keith, i would bet alot of money that you are spot on with the bearing. i had a saturn before my svx, the rear wheel sounded funny when i first bought it, over time it began to wiggle, oneringer, jack the car up, and see if you can push and pull the wheel from side to side, if so it is probably your bearings. i replaced the bearing assembly on my saturn (you HAD to replace the entire unit in saturns) and the problem was solved.
1992 silver/black LSL - 142,xxx miles
power mode switch, ecu crush, intake silencer removal, ecutune, B&M transmission cooler
1971 toyota landcruiser - project.... someday
Old 08-09-2008, 05:06 PM
It could be the bearing, I guess. Definitely not a bent rim. It's not like it's bent, it's like it's falling off! How hard are the bearings to replace?
Old 08-09-2008, 05:28 PM
kwren's Avatar
did you check the lug nuts?
Old 08-09-2008, 05:32 PM
Bearing's are either not bad or horrific depending on the car. Mine were a complete horror show, it took a 6' breaker bar to get some of the bolts loose. I don't know what sort of winter you get, but if they salt the roads you will be in for a rough time of it. If the underside of your car looks new, then it'll be an easier time. There are several how-to's all over this forum about replacing the rear bearings.
Do you get a loud noise from the rear when the car is driving? If the bearing is bad enough for the wheel to be wobbling around it would be roaring like a jet engine back there.
Old 08-09-2008, 05:55 PM
not real noisy
Old 08-09-2008, 08:35 PM
kwren's Avatar
might be past noisey
Good luck working it out.
If a bearing you could remove the bearing housing and have a new bearing-seals pressed in at an automobile supply that has a machine shop and reinstall the housing.
**Always good to get a price before committing to take them the business!
Otherwise, a dealer... ouch
Keith
Old 08-09-2008, 08:41 PM
when my saturns wheel bearings went out they didnt make a sound really, it just felt really bad while i drove and the wheel wobbled like crazy, no loud sounds though
Old 08-10-2008, 09:51 AM
SVeXy96's Avatar
SVeXy96 SVeXy96 is offline
Sold my soul to Subaru
Umm, I dunno if it would be the same on all SVX's, but my 92 has horrible rear bearings and it sounds like I'm crushing and grinding a ton of rocks in my trunk, you can't even hear yourself think over the sound of the bearings lol
Meow
