Old 05-02-2006, 07:38 PM
edmsvx's Avatar
edmsvx edmsvx is offline
Info on sound of Knock Sensor (link)
I found this link which is very interesting.
http://users.wpi.edu/~mark944/nested...knockstuff.htm
This has a MP3 of a knock sensor signal.
1992 (JDM) CXD Ebony Pearl 90K km written off hail damage
1996 (CDN) Lsi, Polo Green, 296,000 km
2009 Legacy Spec B
Old 05-02-2006, 07:49 PM
edmsvx's Avatar
Bosch Knock Sensor vs OEM.
Anyone have any experince with a Bosch knock sensor. I need to replace mine and was quoted $167 CDN per sensor at local dealership. I have found a source online in Canada for a Bosch Sensor for the SVX at $58!!!
2009 Legacy Spec B
Old 05-02-2006, 08:34 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
order it they are pretty much the same thing go with the after market.. the wiring harnesses are the same... if they use the same knock sensor as a subaru legacy the one for my moms was cheeper then 58 bucks
Old 05-03-2006, 10:58 AM
Earthworm's Avatar
Meow!
They are less than USD$50 each from Auburn Subaru (formerly 1stsubaruparts.com)
Part# 22060AA031
Old 05-03-2006, 02:19 PM
Cappy Cappy is offline
Formally Capuano
I've been experiencing a maddening engine shudder for the past several weeks, and finally the car threw a CE that my Knock Sensor 2 was bad. So decided to change it, Knock Sensor 1, the fuel filter, and the PCV valve. I removed the alternator, and went to work. It was fairly easy to replace the PCV valve, and fuel filter, but the Knock Sensor 1 was a bear, and knock Sensor 2 was IMPOSSIBLE to reach...even when I tried to move the AC pump out of the way. For the life of me, I can't figure out how anyone has hands small enough to reach in there from the front. So I guess I've got to remove the intake collector, huh?
And by the way, I got all my parts from the Subaru dealer, and the knock sensors were $48 apiece.
Maybe since I have to remove the collector anyhow, I'll install phenolic resin spacers from Outlaw Engineering while I'm at it. Now if I could just figure out what's making my engine stumble...
Cappy
Cappy
'94 LSi Barcelona Red 158,000 miles
'92 LS-L Dark Teal 47,000 miles
'95 Olds Acheiva 104,000 miles
'85 Audi 4000 135,000 miles
'87 Supra 129,000 miles - 2nd JDM engine
Old 05-03-2006, 02:30 PM
Earthworm's Avatar
Meow!
It can be done without doing this but you need someone with small hands or at least a second person to hold the bolt in place while you attempt to start it on the threads.
