Automatic climate control problem
I just had the transmission rebuilt and the valve cover gaskets and seals replaced as well as the spark plugs changed. Now when I put on the Auto climate control, nothing happens. If I use the manual controls, everything works. Do you think something got messed up when the work was being done and what could it be. I am not getting an error codes.
Michael 1994 Barcelona Red SVX-LSI Two-owner:169K 1995 Emerald Green SVX L AWD #80 - Custom intake w/cone filter 99K with killer stereo system 2002 Acura MDX-Touring Edition w/navigation 2008 Toyota Prius 1987 Mercedes Benz 560SL |
Are you giving it time? I see that you're in a colder state, and the car won't give you any heat until it has heat to give.
Does your A/C work?
If it's working in manual and not auto that could be an indication. Try running the diags.
I am giving the cr plenty of time to warm up. The heat and AC work in manual modes. They don't come on even when I take it down to 65 degrees or up to 85 degrees. What diagnostics can I run?
