stock camshaft specs
I am having a performance valve job done on my cylinder head and the machinist wants to know the specs of our stock camshafts. I did a little research on the network and there is A LOT of information on camshafts, in fact too much for a novice to be able to decifer what info i really need.
So that being said, what camshaft spec info will my machinist need to complete his job? I was planning on keeping the camshafts stock to avoid reliability issues and having to convert to solid buckets...now that i think about it, is it possible to obtain a more aggressive camshaft without sacrificing too much daily drivability? thanks in advance. |
Re: stock camshaft specs
Inlet opens 2*BTDC, closes 54* ABDC. Lift is 7mm. Exhaust opens 55* BBDC, closes 9* ATDC. Lift is 8mm. There is a cam that has been used before, welded and ground by Delta Cams. It was a modified Inlet cam that increased the lift to 8mm, with a 247* duration. It helped the torque to continue up the revs a bit further. Harvey.
Harvey, could you please define the acroynms? (BTDC, ABDC, BBDC and ATDC). Thanks, Chris
BTDC = Before Top Dead Center
ABDC = After Bottom Dead Center BBDC = Before Bottom Dead Center ATDC = After Top Dead Center |
Blue is inlet duration. Yellow is exhaust duration. MOP. Is maximun valve opening point, or Lobe center. Harvey.
thanks guys, I'll let pass the info onto my machine shop guy tomorrow!
