Old 06-17-2005, 07:50 PM
SEA Sleeper
The purpose of a thermostat is not to cool the engine. It's purpose is to allow coolant to bypass the radiator to allow the engine to warm to operating temp.
Putting in a "cooler" thermostat wont do anything for you. The engine will eventually reach the same temps. Especially within the time it takes to make one pass and definitely while sitting & running for 20 minutes.
I agree w/ Mychailo when he recommends the 2nd fan and / or oil cooler.
Old 06-17-2005, 09:05 PM
michael's Avatar
michael michael is offline
What Potholes ???
What is your water/coolant ratio?
Wanted: Steering Wheel
Old 06-17-2005, 10:00 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
70-30 or maybe 75-25.
Old 06-18-2005, 12:09 AM
UberRoo's Avatar
UberRoo UberRoo is offline
SVX Appeal
Unless I'm missing something, it sounds like your cooling system is simply in need of a tune-up. It should have no problem keeping the temperature down. Test the thermostat. (Even new ones can be bad right out of the box.) If the thermostat tests out fine, it's possible that the water pump has failed mechanically. (It does happen.) If the pump and thermostat are working, the only other problem must be with your engine or radiator. Oxidation can reduce the ability of the engine and/or radiator to transfer heat. Most cooling systems are designed with a rather small safety margin. If the heat transfer is only slightly reduced, problems will immediately manifest. I don't know of anything that "repairs" oxidation. Fortunately, engines usually don't suffer badly from oxidation, but radiators often do. The radiator may need to be replaced, and - as reluctant as you may be to do so - replacing it is usually the final solution when all others have failed. If you replace it with something from another model of vehicle, make sure the horsepower rating of the donor vehicle is equal or greater. Displacement is also a good indicator, but not a safe bet.
As for cooling your engine at the track, you can lug around a couple of box fans to place in front of the car. Wetting down the radiator would definitely be the most effective solution - if you were permitted. Perhaps you can mist the air passing through the box fans, or maybe drape a wet blanket over the engine?
What is the ambient air temperature at the track?
1994 LSi, Laguna Blue SVX Appeal
1992 LS-L, Ebony Pearl SVX-Rated
UberLocker
Old 06-18-2005, 04:48 AM
benebob's Avatar
Cooling system is in fine shape. W. P. good and nice last it was out 60 miles ago, thermostate functioning as it should.
Car simply has issues with 2-3 dtrivers sometimes in the same heat (as that is what is prefered in some regions) with only short breaks between. The cooling set up is definately less than ideal for such racing. Of course temps have been above 80 most of the time that it has given us issues.
Old 06-18-2005, 05:27 AM
michael's Avatar
What Potholes ???
Could you wire the fan to stay on while you are cooling off?
Old 06-18-2005, 07:31 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
I was thinking along the same lines as Michael -- why not wire the fan into a switch so you can manually turn it on and off? Have you checked your overflow tank at the end of runs to see if it's filling up/overflowing?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 06-18-2005, 09:29 AM
mbtoloczko's Avatar
sans SVX
Have you by chanced checked the color of the motor after a few of these high heat runs? There was a post by SmallCar a year or so ago saying that one of his Vanagon-SVX customers told him the the motor oil temps in the SVX run very high. If that's true, then I imagine the oil temps on your car are probably getting well beyond acceptable levels.
Mychailo
Visit my locker
Old 06-18-2005, 11:48 AM
UberRoo's Avatar
SVX Appeal
A factory cooling system should be adequate to allow you to do stop-and-go's all day long. The trip back from the end of the strip should be more than adequate to get the engine down to normal operating temperature. The only exception to this would be if something isn't functioning at 100% or you're pushing more than the factory horsepower.
UberLocker
Old 06-18-2005, 01:58 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
Send a message via AIM to Stevebsy Send a message via Yahoo to Stevebsy
Fan is good
The second fan will do wonders for you.
On my XT, the mechanical fan is not enough to keep it cool with the AC running while sitting still, but with the electrical fan on, all is well..
Sacrifice the 5 lbs. for a fan and be cool again.
'93 Anniversary Edition SVX 122k - 3.7 FD 5MT Swap, ECUtune 1a1, Bontrager RSB, Mad Restoration underway!
'20 Honda Ridgeline
Custom Oil Caps, Battery Bars, Phenolic Spacers for sale here:
http://www.x35design.com
Old 06-18-2005, 09:25 PM
ssnsltd's Avatar
ssnsltd ssnsltd is offline
That's gona leave a mark.
It will cool better without any antifreeze. Water alone is a much better cooling agent. You can add lubricant to the water if you are worried about corosion.
David
96LSi 102k Laguna Blue
95 LS-L AWD, Safety package, 140k Polo Green
the Chick Magnet:
91 Justy GL EFI 4x4 154k (new motor @120k)
90 Yamaha V-Max
82 Yamaha XJ650LJ Turbo
My Diver Propulsion vehicle:
88 Jeep Cherokee 160k
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
85 XT AWD/4x4 Turbo Space Blue
Old 06-19-2005, 03:01 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
It got somewhat of a test over the past two days...
So far all we changed is increasing the water to AF ratio and adding some of that watter wetter.
It was staying nice and cool, even during the heat I was running with only 6 other cars, I was getting almost no cool down between runs and it still didn't touch the half way mark
Old 06-19-2005, 04:17 PM
thundering02's Avatar
thundering02 thundering02 is offline
Giong back to the beaters...
One more thought flush the system and put in the newer DEX-cool as its rated for -50 and the regular green is -34 degrees... And yes this makes a difference approx 30-40 degrees in a newer sunfire during general street use.
86 GMC Jimmy Blue and Silver- R.I.P.
87 Integra RS ~228k miles R.I.P.
92 SVX LS-L Perly ~186k R.I.P.
89 240sx se red ~165k miles Gone and unknown
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
85 BMW 325e ~ Gone and unknown
85 Ford Mustang getting engine swap now!
05 Colorado ~108k Daily Driver
