Cam Seal
I am going to change my CAM seals and I wanted to know if a puller was required for the sprocket?
hey, speaking of cam seals...just got 2 of mine done and a new timing belt for only 442.18!!!
good luck John Kelli
Previous owner of the Princess Pearlie "Dimples" as of 8/6/03 1992 LS-L Pearl 124k "Yeah, that thingy!" owner of the new 1992 LS-L Pearl "Susie" I am a pessimistic optimistic. I think the worst is going to happen, that way when it does, i don't feel as bad, but if the best happens, i am twice as happy. |
Im Interested
I was thinking of doing this also. If you can, take pictures and let us know how hard or easy it is. Step by step instructions would be nice too..
Chris |
Your biggest problem will be holding the sprocket while cracking the bolt loose. After that it's a piece of cake - no puller needed.
I don't know what your plan is for removing the seal, but I usually use a 1/8" drill bit and carefully drill a hole in the old seal. Do not scratch the camshaft with the drill bit. Then insert a hook or 90° pick into the hole, using a pair of side-cutters or pliers to grip it while prying against the cam snout. Be sure to lube the new seal before installing.
Silicone. Got that on your other post Beav as always in your tool box. Thanks John |
Silicone grease works great ofr many things. I really like it. Use that also on my Anderson windows so they crank open easy. |
Question
IS this the same strap wrench that Sears sells??
Re: Question
