Old 09-05-2012, 09:46 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: TPS problems
update: New tps,maf didn't help. The timing is dead on. It's running good now but it itermittently runs like I stated above when I turn the car on so i'm going to check the coils, crank,cam sensors to see if they are in spec and replace the fuel filter since I did swap the motor.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 09-06-2012, 08:26 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Re: TPS problems
Seth, for some reason I would replace your TB...I'm going to replace mine because of similar symptoms as you've been describing. If that doesn't work for me, I may replace the IRIS valve in the future because my symptoms happen in the 2000-2500rpm range....
When do you notice this in the rpm band?
1995 Subaru Svx L / AWD
Old 09-07-2012, 07:08 AM
Re: TPS problems
Well Matt, so far its been awsome for the last couple days with no problems. It wouldn't do it in a specific band either just whenever you give it more than 1/2 throttle. I want to say maybe the injectors or some bad gas was on/in the new motor when I put it in and worked its way out but I cant be certain.
Seth
Past subies:
Other toys:
Old 09-07-2012, 08:00 AM
dragoontwo dragoontwo is offline
Re: TPS problems
One thing I haven't seen suggested yet is to chek the ground on the right rear of the intake manifold. Old tom suggested I check mine when I was having some charging issues. It didn't fix my issues, but I only cleaned and added a ground jumper to this terminal and it smoothed my engine out a bit. When I get my intake manifold off, I will do a better repair on the ground. It looks like it is the grounding point for at least 4 different components/sensors on the manifold.
'92 SVX LS Pearl White - 6mt
Old 09-07-2012, 06:50 PM
Re: TPS problems
I did that one a while ago when I was checking the harness.
Seth
Past subies:
Other toys:
