Old 07-26-2012, 07:50 PM
davew833 davew833 is offline
Radiator crack...
Anyone had any luck patching the inevitable crack that appears on original radiators under the filler neck after a while? I've heard epoxy, JB weld, etc., but is there any trick to the application to make it work better/hold longer?
davew833@yahoo.com
Former 6-time SVX owner
Old 07-26-2012, 07:54 PM
Re: Radiator crack...
drill a small hole at each end of the crack to hopefully stop it from continuing to spread. Prep the surface by sanding to give whatever your using something to bite on to.
Old 07-26-2012, 08:30 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
What Dave said plus replace that upper rad hose and check your motor mounts for excessive play.
Old 07-26-2012, 08:39 PM
SVX8588's Avatar
SVX8588 SVX8588 is offline
JB marine weld works pretty well. I didn't drill holes in mine but I sanded it with like 50 grit sand paper. Lots and lots of sanding. You want it really rough.
Then I used two applications of JB weld. First about 1/8 in thick and the second (sand again beforehand) about 3/8 thick on top of the first layer. Basically I filled up the indentation in the plastic radiator top to make it have a square corner.
It lasted about 6 months until I bought my aluminum radiator, so I was pretty happy with it. Make sure to let the JB weld cure for long enough.
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 07-26-2012, 09:04 PM
Or bite the bullet and buy a new one for $131.80 shipped.
http://www.ebay.com/itm/1992-93-94-9...m=120837762868
Old 07-26-2012, 11:04 PM
kwren's Avatar
kwren kwren is offline
Lots of things can happen when your car goes down the road and your coolant doesn't go with it and none of them are good. Since any patching is temporary... Get yourself a new Radiator.
Keith
Old 07-27-2012, 09:41 AM
BRADY's Avatar
BRADY BRADY is offline
SVX Addict
Send a message via MSN to BRADY Send a message via Skype™ to BRADY
Wow! That ebay radiator is CHEAP!
I paid over $1,000 to get my new radiator - mind you it is a PWR core with a custom polished chrome top.
I had NO luck with patching the top tank of the OEM radiator...
As you are in the US of A and so is that ebay radiator, I would recommend not messing around with such a crucial part of the cooling system.
That's my 2 cents....
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com
Old 07-27-2012, 08:23 PM
immortal_suby's Avatar
Thread Killah
Good advice - gamble with that radiator and the next thing could be a headgasket.
Locker Link
2015 BRZ Limited 6MT
