Old 09-22-2004, 01:01 PM
tracedog67
tranny fluid change
I need to change the fluid in the tranny of our '92 LSL with 160k (not a flush) and wondered how much fluid and what type should I get? I do have the external filter which may require more fluid?
Tdog
Old 09-22-2004, 02:19 PM
Whoru465's Avatar
Whoru465 Whoru465 is offline
The name's...
Send a message via AIM to Whoru465
Should be able to just replace what you drain out, as not all of the fluid will drain from the tranny. I think it's only going to be 4qts or so. I can check my manual when I get home. Otherwise, do a search, I know the info exists in another thread that I actually started some time ago...
-Mike
'92 Pearl LS-L (sans Spoiler) #0993 Mfg. 5/91
"It says here, 'Breakfast any time'...
That's right...
In that case, I'll have the pancakes in the Age of Enlightenment..."
Old 09-22-2004, 03:11 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Best way to do it is to measure the amount of fluid you drain and replace that same amount. The owner's manual says 4qts per change - with the trans having a 10qt capacity. Some members have been able to drain 7 qts by putting the front-end up on jack stands and letting it drain for ~ 1 hour.
-Chike
2006 Steel Gray WRX TR (sold)
Old 09-22-2004, 04:48 PM
BoondockSVX
I always use wheel ramps and I usually have to put in 6-7 quarts.
- Jim
Old 09-22-2004, 06:14 PM
lee lee is offline
I jack up the passenger side (the drain is on the driver's side) and get just at 7 qts consistently.
Old 09-22-2004, 10:07 PM
Whoru465's Avatar
The name's...
Not to be OT, but how do you get ramps under the front end, I have had no luck in trying to roll the car up onto them? Am I missing a secret front end ground clearance hydrolic thingamabob?
-Mike
That's right...
Old 09-22-2004, 10:24 PM
BoondockSVX
Regular yellow ramps with two 2X4s about 2 ft long. It makes the ramps more gradual.
- Jim
Old 09-23-2004, 12:24 AM
Old Fogey
Check these out. Turned my very frustrating set of ramps into very easy to use tools.
http://www.subaru-svx.net/photos/user.php?RojoRocket|20012
oops! view "ramp pics"
Glenn
Old 09-23-2004, 08:18 AM
n00b on demand's Avatar
I cant get my car on my ramps either. The front end will never make it up. It moves the ramps out of the way actually. I think what we need is ramp extentions or as boons said we need some wood.
Old 09-23-2004, 10:57 AM
BoondockSVX
If you lack wood, you're not completely out of luck. Just line them up in front, and kick the ramps really hard underneath the car. They should just be able to wedge the tip of the ramp underneath the front wheels. This is still less than ideal, as I find it kinda difficult to drive up ramps that steep.
Having wood makes it much easier to keep it up.
Old 09-23-2004, 11:02 AM
Whoru465's Avatar
The name's...
Haha. Good point Boondock, thanks for the tip
Rojo, did you build those or buy 'em? I'd love to get a set. My jack struggles to lift the beheamoth!
-Mike
That's right...
