SVXBot
Old 06-01-2019, 11:41 AM
briankk briankk is offline
Fuel Pump..
My 1994 SVX in in the shop. Four pumps, nothing fits, Anybody?
Old 06-01-2019, 12:36 PM
irox irox is offline
Re: Fuel Pump..
This is the fuel pump that I using to replace my stock pump:
https://www.oreillyauto.com/detail/b...992/subaru/svx
I would imagine there would be a bunch a generic pumps would should work.
When they say it doesn't fit, what do they mean?
This job was a major pain in the ass, and ultimately my problem turned out to be something different (bad MAF connector).
Good luck!
Ian.
Old 06-01-2019, 12:53 PM
Gamesy's Avatar
Gamesy Gamesy is offline
Re: Fuel Pump..
upgrade the fuel pump?
Old 06-02-2019, 09:34 AM
svxcess svxcess is online now
Pristine Green Polo Machine
Re: Fuel Pump..
many members have used this one as a replacement with no problems.
https://treperformance.com/i-642-sub...1992-1997.html
1996 Polo Green LSi #216...137,900 miles...
JFICX8659TH100216JF1CX8659TH100216........Mfg. Date: 11/1995......... Service Date: January 2, 1997
HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, Raceconcepts dimpled/slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler.
R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a COW March 4, 2016
2014 Hyundai Elantra Limited ...101,000 miles. Actually quieter and smoother than the SVX
5th Registered Network member —2/21/2001
Old 06-03-2019, 05:21 AM
theflystyle's Avatar
Re: Fuel Pump..
I just installed this one and it is working well.
https://www.highflowfuel.com/i-10385...1992-1997.html
I would also suggest checking out my thread about my fuel delivery issues. Could be the fuel pump plug causing your lack of fuel.
1994 SVX LSi
1994 Legacy L
WRX Wheels
2008 Legacy 3.0R
HID, Bilstein F/R, WhiteLine LCA Bushings, Potenza RE970AS PolePosition Tires
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
