Old 01-13-2007, 12:46 PM
cdigerlando cdigerlando is offline
Oil spewing out of the breathers.
I've got oil spewing out of my breathers. Any ideas?
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
Old 01-13-2007, 01:46 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Chuck,
Pics of your set up? Normal set up is that the PCV system takes care of this...
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 01-13-2007, 04:16 PM
Check the PCV valve and see if works. That may be your problem. That should not be happening.
Old 01-13-2007, 04:20 PM
Oil out the breathers.
Chuck sounds like you are getting boost into the crankcase. How have you got the crankcase ventilation set up?
Old 01-13-2007, 06:31 PM
I would not expect Chuck to be running his improved engine with faulty piston rings, or be stupid enough to have some other direct cause.
Old 01-14-2007, 08:56 AM
Engine Dead
I think this is the case. It just started happening, so I don't think it is a problem with my crankcase ventilation, which is ventilated directly to the atmosphere, along with my cam vents. I am thinking either rings as trevor said, or perhaps a hole in the piston. I have had no detonation events that should have caused this. It is an older motor though 135k. It may be time to bite the bullet and just pull the engine and rebuild it.
I am also getting a fuel smell from the vent. I seem to miss once in a while as well.
I think it is pretty apparent from the folks who are using FI that more is required to achieve this. Intercooling and lower compression for starters.
Chuck D.
Old 01-14-2007, 09:43 AM
SVXRide's Avatar
Chuck,
ouch Have you pulled the plugs to see if they tell you anything? Might also be a good idea to check the timing belt - I'm wondering if the intake and exhaust cams are "off" thus throwing off the combustion event (i.e., raw gas being shot out the exhaust, pressurized crankcase gases being pumped out the vents, ...)
-Bill
Old 01-14-2007, 10:20 AM
Plugs
Haven't pulled the plugs since this has occured. I doubt it is a timing belt issue. It has fairly new timing belt, and it was running fine before this occured.
Chuck D.
Old 01-14-2007, 08:28 PM
SVXRide's Avatar
Chuck,
yeah, just trying to come up with something other than "you must have hashed a cylinder" You still might want to check the cam and crank sensors.
-Bill
Old 01-15-2007, 01:50 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
you should also check compression that will tell you once and for all if it is the ring or piston
- John
Old 01-15-2007, 03:11 PM
I don't think it has a engine problem, or there would be a smoke screen out the back. Is there any way boost can get from the inlet piping to the crankcase, like the little pipe that runs from the air duct into the crankcase, for the Case ventilation? Any way it can get in there?
Old 01-15-2007, 03:18 PM
sensors
Originally Posted by SVXRide
Chuck,
-Bill
I am running stand alone management. So this would not affect anything.
Chuck D.
Old 01-15-2007, 03:20 PM
Compression
I would love to do this. Checking the compression on this engine is a nightmare though. Anyone got picks of a good compression test setup would be appreciated.
Chuck D.
Old 01-15-2007, 03:22 PM
Are you speaking of the pcv? My pcv is disconnected. All of my breathers have ventilated to atmosphere for some time.
Chuck D.
Old 01-15-2007, 04:23 PM
Well looking at it Chuck, for the oil to come out the breathers, there has to be, either too much oil in there, or there has to be something producing pressure in there to blow the oil out.
If it was a piston or ring problem, there would be smoke out the back. No smoke, no problem.
The only logical reason is, that there is boost pressure finding its way into the crankcase. You have the cam breathers open, the PCV valve removed/blocked? All the pipes that run from the air duct, near the throttle bodys, to the rear of the block, are removed/blocked?
I haven't seen a Pict of your setup, so I don't know what you have got there.
