tire size help
I've got a set of Lexus IS300 Sport Design wheels (17x7) on my car with the factory Lexus size tire of 215/45/17 on them. I want to change tires to a wider tire and I'm not sure what is best to get or what will even fit. I'm thinking 235/45 or 235/40. Does anybody know if these will fit without rubbing or harming something else?
Thanks, Nate |
What's the offset on the IS300 wheels?
chike, I'm looking for the offset of the IS wheels but haven't been able to find it. I'll let you know as soon as I do. Thanks for your help.
Nate |
Nate |
Watch the wheel width as that's more important to fitting a wider tire than the offset. I believe the IS uses a 7" wide wheel with a 35mm offset.
Todd
Down to none |
chike...
Hey, the wheel is a 17x7 50mm offset. Do you think I could fit 235/40 or 235/45's on there and not rub in the SVX? I know a 235 will fit the wheel because a couple people at the dealership I work at have a staggered wheel setup on their IS300's using 235's in the rear.
Thanks Nate |
235/45-17 is a bit wide for a 17x7" rim. I wouldn't run anything wider than a 225/45-17.
