Urgent!
I went downstairs today and I tried to start up the car today. The
battary comes on but the car does not start. I can't even pull it out of park. I am really concerned and pissed. Can someone help? I checked all the fuses already. Thanks Lwin
As you posted your question yesterday you perhaps already have a answer/solution. The symptoms sound like either a dead battery or a contaminated connection, or two. There is a relay and solenoid to release the shifter from the park position. Both require a good bit of power (compared to a light bulb for instance) to operate. Lights and radios will usually work with a very discharged battery but not things like wipers, power windows, etc.. There should be a release button near your shift lever to allow for moving it out of park when the battery is dead. Mine has one at least.
My suggestion would be to recharge/replace the battery. Good luck, JP |
<<lightning_8669
Here comes the rain!>> When it rains, it pours -- RIGHT? Lwin
Yea and verily! But at least my lawn is looking slightly less flamable I actually might have to mow it someday.
try this
Mine does this all the time. It has a bit of slack in the shifter and the neutral saftey switch will not allow the car to turn over. I either have to push the shifter fowards while trying to start the car, or use the shift lock to put the car in neutral and start it from that position.
Just my $0.02 Chris (SVX Admin) |
Re: try this
Paul 1992 LSl (Black Mica) 1965 Mustang G.T. Fastback 1990 Mustang G.T. Convertible 1986 1/2 Nissan 4x4 2004 Vovlo XC70 (wife's) Wonderful Wife Wonderful Son 2 Cats Incredibly blessed! |
Mine does this too. I call it a anti theft device. Just push the gear shift forward a little and the car can start.
