Is This A Fuel Pump Issue?
My 92 chokes sometimes and jerks back and forth, and sometimes dies from it when giving it more gas.
Mechanic quoted that it was a 90% fuel pump issue, before i get it replaced any other thoughts on what the issue might be? Thanks |
Re: Is This A Fuel Pump Issue?
Change your fuel filter first. - Ed
http://www.ehow.com/facts_5125417_si...el-filter.html http://www.buzzle.com/articles/signs...el-filter.html |
The pressure should normally register as between 34 - 38 psi or 235 - 265 kpa.
Ok, thanks a lot for the info.
In general what else can cause such an issue? |
Did you change the filter and check the pressure yet?
When my MAF failed on my Legacy, it had all sorts of strange behavior, including the behavior the OP mentioned. I would check that out too. Find someone nearby who has one that works, swap and see if the behavior goes away.
More likely to be a sensor issue than a fuel pump issue.
Fuel pump issues usualy manifest as issues at higher rpm if they are not putting out the flow/pressure. |
