New to the SVX family; first problems: noises...
Hi everybody,
We've bought an SVX recently; nice car, I have always admired its design and finally I own one '96, black, LSi. However, it came with some (hopefully small) problems - which went unnoticed when I bought it. First, when the engine starts cold, there is some screeching noise for about 10-15 seconds. Then it runs smoothly, without producing any bad noises/vibration. Engine oil is okay, clear and 1/2" above the "L" level. Timing/driving belts were replaced by the previous owner recently. What could it be? Also, there is a slight screeching noise when a sharp left turn is made. I suspect CV joint. However, what puzzles me is that the noise is screeching, like a friction, not a clicking/cranking sound. Since it has only started a couple of days ago, I hope the joints did not take any damage and the repair needed will only be grease/boot replacement. However, if it is a joint failure and a joint or half-shaft is to be replaced, what are the ballpark estimates for the cost of repairs and the time it takes? I tried to check availability of half-shaft assemblies and only found re-manufactured ones - how reliable are they? Are new ones available? I scheduled an appointment on Friday with the dealer where we bought the other vehicle in our family, Capitol Subaru of San Jose. However, I would be grateful if anyone could recommend a good mechanic for SVX in the Bay Area, preferably in the south bay. Thanks in advance! |
O.k I'd suggest staying away from the deal because well they like to charge an arm and a leg and another arm. But the rattling might be CV joint and I will suggest because I just had this happen if the screeching noise gets worse or persists then get it looked at. Turns out that my timing pulley's bearings were shot. GL and I hope they find nothing major.
Part of your problem could be as simple as...
the new belts not being not being properly adjusted.
rebuilt cv half shafts
are only about 60 bucks exchange
{Screeching doesn't sound like cv shafts} |
I get a screaching from my rear e-brake spring rubbing on something when I make a right turn. Might be the same kind of thing.
ALICE: 2005 Forester XT (Ice Racing Machine) River: 1992 SVX LS-l 125,000 # 0930 (getting fixed up at the moment) |
a good mechanic for that kind of work? a monkey! tighten your acccessory belt its loose
www.licmotorsports.com
~Silke '92 SVX LS-L - faded Ebony - sold |
I got a call from service shop at Capitol Subaru; they said that both front half-shafts are to be replaced and quoted $1475 for that, and recommended changing the brake pads for $300. They also quoted that there are some "additional problems that need to be fixed". Given that one of the responses suggested a price of ~$60 for a remanufactured half-shaft, a price of $1475 seems somewhat too high.
So, the question about good service shop for SVX in Bay Area, preferably south of the bay, remains. Aside from the LIC motorsports in Novato (which is 90 miles from me), is there any good shop somewhat closer to San Jose? |
to tell you the truth the half shafts are something you CAN do on your own, if you can afford not driving for a day. there's a good how-to on it in the How-To documents, or was it a post.. regardless I remember searching for it and finding a How-To.
i think there's a guy here named EdfromSF whos in the bay, and although he isnt exactly in the 408 im sure he can direct you to a nice place. i've always done the smaller jobs on my own.. also check the SVX Shop Search, I think there's something about a guy owning a SVX in san jose and being the head mechanic or something |
jsvxstyle
Is in ANTIOCH, CA, if that is close to you (I know CA is a big state) you can contact him, to check on rates....
you can try the mechanic files... www.cartalk.com
IMHO if you can drive 90 minutes to a reputable repair shop, I would do it. If they are recommended by someone on this network, you know they know what they are doing and you won't get ripped off. I drive 2 hrs to have YT ( Tomssvx/ AWD Inc) work on my car because he came highly recommended by others on this network. As long as my car can "Limp Mode" the 2 hrs, I will always try to have him fix it. So if you can make it the 90 minutes, take it to the reputable repair shop. You won't be dissapointed.
Paul 1969 Corvette 1995 SVX L Safety Option Package, HID's & Awsome Braking (Svxfilies/TomsSVX), JDM Clear Corners, JDM Boxer Engine cover, Transmission Cooler, AND NOW JDM FOLDING MIRRORS! 1995 Corolla 2003 Highlander |
New front axles are 69.88 each plus tax and $35.00 each to install(plus tax). I drove over 2 hours to get to his place. I must fest up though i had other work done also...........Tom is Cumberland Md which wouldn't help you but maybe you can purchase the parts from him.\ You can contact here: http://www.svxfiles.com/
HENRY 92 SVX Claret(No More) 12 Camaro ZL1 89 Yamaha FJ1200 07 Yamaha FJR1300 "GO RAVENS" |
Thanks everybody!
As to LIC motorsports shop in Novato: I called them on Friday to check whether they work on SVX. The person who answered was not able to tell that, they promised to call me back. I am still to receive that call And, I am not sure if the car will do 90 miles even in Limp mode. It seems that the CV breakage was progressing rapidly - so when I was picking her up, it made the noise with even slight left turn. So I decided to fix at least that breakage. Fortunately, the shop was flexible on the price. Probably, next time I'll try to contact LIC motorspors again to do some tune-ups. |
