Hood Insulator Cleaning
My SVX had a massive powersteering leak that soaked my hood insulator. I have since gotten the leak fixed but since it's soaked in my insulator, i get a burning smell whenever i get out of the car.
I took the insulator out and tried cleaning it with degreasers and other cleaners. It still has a grease stain on it. My question is, will the paint on my hood get damaged if i leave this out? what other problems will i get if i leave this off? Thanks for your help Clark |
I believe the paint will eventually dull from the added heat. Also the engine will cool much quicker in the winter.
Also, don't use a pressure washer on it.
Dan Pentiums - Melt in your PC, not in your hand! Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete. His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing. Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing. Mods: PWR Radiator! Problems: Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too! Ticking from front of engine, passenger side - Stuck lifter? |
Thanks for the info
Yeah that stuff falls apart pretty quickly if theres too much pressure. ive been letting it soak in the solution then i rinse it and try to soak up as much as i can with towels. It's going away, but it's taking forever. This will be my 5th time washing it. I might just have to pony up the $90 to get a new one if it doesn't completely go away after the 6th or 7th time |
Re: Hood Insulator Cleaning
Just for reference, New hood insulator pads are still available. 90815PA000. About $100.00 each. Special order from Japan. The 18 hood insulator clips that hold it in are the only ones that work. I tried 3 different clips from Subaru today for the hood insulator pad. The original ones for the SVX are the only ones that work. 90814AA000. About $1.90 each They are a lot stronger and secure than the others. I think that is because the SVX insulator pad is significantly larger and heavier than with other Subarus. It has to hold up that weight against gravity when the hood is closed. The other clips don't have much pressure exerted on them and are used to keep plastic body parts aligned properly. The other clips just press into the SVX holes and have just 4 tiny points of contact. They are easy to remove. The originals actually clip in with a solid snap (think toggle bolt). They probably become brittle with age and heat over the years. I have yet to remove one intact. The only reason to ever remove the clips is to replace the insulator pad. These are the new style clips. Here is the OEM clip. Designed for one-time use.
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 06-24-2020 at 12:20 PM. |
