View Poll Results: How interested are you | |||
Very, extremely, sign me up!! | 14 | 20.00% | |
Maybe, depending on what it would cost | 48 | 68.57% | |
not really but I may think about it | 2 | 2.86% | |
STFU!! I wanna keep my slushbox | 6 | 8.57% | |
Voters: 70. You may not vote on this poll |
Thread Tools | Display Modes |
#106
Another Q
cool. I wasnt sure so I had to ask. another question I had is how do i know if I have a component driveshaft? Im thinking the best way to do it is getting it lenthened then rebalanced.
Eric Rebuilt P/S pump info... http://www.subaru-svx.net/forum/showthread.php?t=50918 If your car wont start info... http://www.subaru-svx.net/forum/show...ighlight=click |
#107
the legacy shaft is know to fit well with no downsides. shotgunslade has one in his 5mt and I have kept close tabs on his car and he is not experiencing any problems. The component shaft looks like 2 driveshafts held together by a flange(much like the rear diff flange)
Tom |
#108
Dan |
#109
the 6mt is bascially the same except you need to extend two other peices on the shift linkage as well for the reverse lockout to function properly. there is also no need to extend the driveshaft or the speedo cable
Tom Last edited by TomsSVX; 03-24-2006 at 10:19 AM. |
#110
#111
the shaft I used in shotgunslade's car was out of a 99 outback... Bearing bolted riht up
Tom |
#112
clutch?
Tom...Do you reccomend using a stage one Exedy clutch kit with your kit. OR do you think just the clutch will be sufficent? I found the kit for $340 but I found just the disk for around $140. Where do you reccomend purchasing it from?
#113
the stage 1 is good for stock power applications. I would highly suggest getting the whole clutch kit as the higher forced clutch is all in the pressure plate anyway
Tom |
#114
Silly 5 speed questions
Okay so im pulling all of the auto trans wires threw the firewall and im trying to figure out should I remove all of the two big connector wires or do I need any of that crap? I also found my starter bolts run all the way threw the tranny. The SVX motor has provisions for one. Do i put a heli coil in it? 2 plugs on the rear of the 5 spd...one is reverse light switch the other is ?
#115
Of the 2 large tranny connectors, one is not used, the other is used for the reverse lights, cruise and neutral grounding.
#117
more wiring questions?
First off..Sorry tom if im hijacking your thread but I think this will be the most complete thread about the conversion. ..Im trying to get all of the wiring straigt. In the huck/toms write up the depressed clutch position sensor must close the circuit when depressed. That switch goes up to the black and yellow wire and the blue and white wire on one of the auto tranny connectors. The reverse lights hook up to the reverse switch on the 5 speed im assuming. and i guess I dont need the in gear hooked up to anything?. Also I need to make a jumper on the Ecm side to enable cruise. and im still fuzzy on the auto shifter selector harness. thanks guys
#118
Tom |
#119
Its not a jumper for the cruise (my fault) its the tourqe control jumper wire. Is that still needed? Do i need to do anything with the interior auto selector harness?
#120
I am pretty sure thats the harness you are splicing into. Do not do the torque control jumper, will cause a very large hesitation. Thats about it
Tom |
