5 speed conversion wiring??
whats up guys...first off, this is my first post. Not new to the forum tho.my dads been a a membe for a while. he and i have svx's and i must say the forum has been a lot of help. Great to see svxers teaming up... Anyways......
i have a 92 pearly which im converting to a 5 speed..using a 2004 wrx trans. BIG thanks to Tom for the kit... so worth it....did a great job on the pieces too. im pretty far along..only been at it for 5 days...few hrs a day... just got the pedals in yesterday... man that was a pain! Im going to put the trans in today i hope... should move quickly with Toms kit since i have all the components ready to go.. Just a question about wiring?? seems straight forward 1. NSS 2. Reverse 3. VSS that parts simple, but is that all the wiring? huck369 says something about disabling Torque Control?? is there ignition lock or anything else im missing? Thanks in advance for any help. really appreciate what you guys do.. |
Re: 5 speed conversion wiring??
I do not recomend the torque control disable, it caused some sever hesitations in my car when I had done it. Make sure you unplug the shift lock control module under the center console... might as well remove it, then you don't have to worry about the ignition getting stuck. Hope this helps, feel free to give me a ring if you run into any trouble Tom |
sorry to hijack a little but what is this about the torque control causing hesitation. If you can point me in any direction that would be great cause i have no idea what i did when I swapped the tranny in, and i'm definitely having some horrible hesitation down low. Over 4k its like there is no problem.
Tom |
As far as i can recall no i did not. About 99% sure i didnt.
well then you likely have a seperate issue. the jumper is the torque control thing I had mentioned earlier. If you did, cut the jumper wire out and you should be fine
Tom |
Thanks a lot...just what i needed to know...
got the trans in today and half the wiring done.. tranny put up a good fight. oh yea... i was wondering how the VSS is going to work, since the signal is going to the TCU which im removing?? i asume it must be going to the ECU some how? |
The VSS wiring splits three ways out of the sensor. 1- Dash 2- ECU 3- TCU If you remove any one of these it will still operate the others just fine. Keep us updated on your progress!! Tom |
thanks Tom... Knew it had to work, was just curious... will keep you updated..
going to put the shift linkage in and then i guess its time to button the job up... Thanks again for the kit... everything fits beautifuly far... so exited to get this thing on teh road..! |
