Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania
Old 06-05-2003, 09:10 AM
mbtoloczko's Avatar
sans SVX
Originally posted by SVXtasy
Saying a blanket statement like "Do not buy dimpledrilled/slotted/crossdrilled rotors" is pretty narrow minded seeing the best breaks in the world are slotted/crossdrilled, Brembo for instance. Just my 2 cents.
SVXtasy
Its generally known that crossdrilled and slotted rotors will eventually crack. Its just how long it takes. Some cars can get away with it because the size of the rotors relative to the weight of the car is much larger, and the rotors are more effectively cooled. In this way, the temperature gradients are much lower which mean that the thermal stresses driving the cracking phenomenon are reduced, and if low enough, cracking can be delayed for a very long time.
Mychailo
Visit my locker
Old 06-05-2003, 09:53 PM
Paisan Paisan is offline
Send a message via AIM to Paisan Send a message via Yahoo to Paisan
SVXtasy
Well we are talking about SVXs here, and there aren't a whole lot of brakes out there for em. 99% of the people reading this will be fine, cause they don't push em to the heat limits that I do on the track, heck most people here never even would think of going to the track. So as a STREET rotor they are fine. But as a RACE rotor they aren't going to cut it.
-mike
'14 Touareg TDi | '04 Nissan Armada LE | '14 BRZ
http://AZPInstalls.com
Old 06-06-2003, 08:43 AM
Green1995SVX
-mike
I agree totally with what Mike just said. For track use, the slotted / dimpled rotors are not a great option, but can be a big improvment for mild-moderate street use.
Mike
