#226
Re: 285 whp!
My real pet peeve is simply the shape of the pan. It's a soup bowl. Not conducive to oil control! A half-round shape like that has no way to keep the oil from climbing the sides while braking and cornering, and to a lesser effect even during acceleration. Even if the baffling keeps it away from the crank, the oil might not be anywhere near the pickup. And even if the engine is not under load, it may very well be spinning 8000 rpms at that given moment, and even 1/2 second of starvation at that rpms will not be kind to the bottom end parts. |
#227
Re: 285 whp!
-Bill
#228
Re: 285 whp!
Bob what compression will you guys go with?
Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#229
Re: 285 whp!
It'll be squared off with some kickouts. None too radical, still need to be able to access the pan bolts as well as the header bolts. And 4 trap doors most likely.
#230
Re: 285 whp!
Jack was talking about 12:1. I think he wants to refrain from having to buy 'straight' racing fuel. A mix might be okay however (93 octane + 100 octane). Budget is always looming!
#231
Re: 285 whp!
Tom |
#232
Re: 285 whp!
Small update here.
I completed the oil pan with trap doors for Jack's EG33. Some teasers. The rest of the pics are here. The shortblock parts for the new engine are done, Jack is waiting for the custom head gaskets to arrive and then assembly of his new engine will commence. Compression ratio is 11.95:1, the new displacement is a bit over 3.5 litres. More updates when it's finished and dynoed. |
#233
Re: 285 whp!
Bob...talk to me about cooling and inlet.
What are your plans for each? I notice the oil cooler plumbing...are the sandwich plates effective? Does it provide the right level of cooling? Can the oil pump deal with it? I'm actually considering going for individual throttle bodies as a mate can make them pretty cheaply...have you looked at that? Matt |
#234
Re: 285 whp!
Jack and his machinist again. Quote:
HTH, |
#235
Re: 285 whp!
Bob, Looks great bud! I was thinking of a dry sump the other day... still lingering... Need to weigh my options
Tom |
#236
Re: 285 whp!
Bob,
Nice! What's the total oil capacity now? -Bill
#237
Re: 285 whp!
The JDM Dual AVCS engines apparently use the same oil pump as the SVX uses a wider pump rotor than the normal STi's. The 08+ STi is a dual AVCS engine so should have the wider pump rotor too.
#238
Re: 285 whp!
-Bill
#239
Re: 285 whp!
Tom |
#240
Re: 285 whp!
We'll find out when he adds oil.....
I suspect he gained at least two quarts. |
