which parts?
on these pages, which parts do i need to replace the speedo gears in the differential? they are not very expensive, so i could just buy them all and replace them all, but if i do that, are there any other parts i need to get too?
http://www.subaruparts.com/diag/?mod...category=156-A on this one, its part # 11 and 19 http://www.subaruparts.com/diag/?mod...category=190-A on this one, its part # 17 im just giving the obvious speedo parts. do i need all these and is there anything else i need? i want to have all the parts before i drop the tranny out and start fixing it all. thanks for any help!!
1992 silver/black LSL - 142,xxx miles power mode switch, ecu crush, intake silencer removal, ecutune, B&M transmission cooler 1971 toyota landcruiser - project.... someday |
This probably didn't work the way you intended...
You have to be logged into that site to see those images.
If I had to guess I would say that you only need #11. That's the part that contacts with #17 and is what probably what is broke. I recently swapped out a broken front diff and none of the speedo parts were damaged. While examining the diff I thought that #17 looked pretty robust but I suppose since it is just plastic it could be damaged too. |
