Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Brake Upgrades
Old 05-07-2008, 08:48 PM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
Again.....
I wasn't looking to use Brembo's, I was looking at the WRX 4-pots. I now know they can not be used.
I wasn't looking at them for larger rotors, I was more interested in reducing unsprung weight and having a more balanced and accurate caliper.....
I know the Brembo's need a larger rotor and in one of my posts even said I wasn't looking for the purpose of larger rotors.
I know fluid is one good way to reduce brake fade.....I also know about the different pad materials.
Biasing the pads sounds like it could work nicely, figuring out the best combination will be the only tricky part.
Dustin
-Dustin
Old 05-07-2008, 09:12 PM
Haven't you driven marisa's car? she has um, I forgot, akebono ceramic pads, s.s. lines and fancy rotors... What do you think of the way her car brakes? I thought it was a firmer pedal and slightly better braking.
blk 92' LSL w/ average mods
Old 05-07-2008, 09:34 PM
Originally Posted by odepaj View Post
Again.....
Dustin
Dustin, I was not pointing it out to you...
Old 05-07-2008, 10:22 PM
odepaj's Avatar
Killer of threads
Yeah, she has ceramics. I didn't get to drive it hard because we were just listening for a rattle. I did like the feel of the S.S. lines though!
Dustin
-Dustin
Old 05-07-2008, 10:28 PM
yeah, they are a nice upgrade. I was late for a job interview today and had to do about four 0-90-0 in a matter of 2-3 minutes and my brakes never once induced anit-lock, but rather just faded a little. The pedal wasn't as mushy as in my truck, but not really great either.
So when you coming up to austin to go for a fun drive?
Old 05-07-2008, 10:32 PM
odepaj's Avatar
Killer of threads
I'm lost as to the reason for your post then? I know I jumped the gun and retaliated alittle "harshly" but with how many times I said I wasn't looking to use the Brembo's I just couldn't see why the fitment of the Brembo's kept coming up?
As of now my stock brakes will stay just that (aside from fluid and S.S. lines).
I thought it would be nice to have the WRX 4-pots for weight reduction, better heat transfer, and a more balanced caliper.
4 pistons (2+2 layout) will be more balanced and precise along with having a better "clamping" force to act on the rotor/pads.
Example: Four 10" speakers will have better response and clarity then two 12" speakers because the four 10's (while being smaller in diameter) add up to a larger cone area than the two 12's.
More can be done with a smaller 4-pot caliper then with a 2-pot. It also can save weight while still adding mass (for cooling)
Dustin
-Dustin
Old 05-07-2008, 10:35 PM
Believe me, i would like opposing calipers simply for more precision in my braking, but right now the stockers are fine.
I had said that because Chris had stated that all one would need is a custom rotor to make the Sti Brembos work, which is not the case and that should be crystal clear to anyone reading this.. Otherwise people are going to buy them and be awful pissed off when they find out the hard way.
P.S. I am not 100% but the clamping force/friction surface of the 4 pots might not even be up to snuff against our slider 2pistons so before looking too far into mounting make sure it would indeed be an upgrade
Old 05-07-2008, 10:45 PM
odepaj's Avatar
Killer of threads
Ah! Ok, sorry about the confusion then.
Yeah, I've actually already given up on the Subaru 4-pots. Eventually I will look into different 4-pot calipers but thats a long ways down the road still. The pads for the 4-pots did look bigger than ours though, I would think they have greater force. Some of the guys with older WRX's ('02-'03 with the 2-pots in front) seem to like the 4-pots as an upgrade. The '02-'03 calipers are similar to ours (2-pot sliders) but look alittle smaller.
Dustin
-Dustin
Old 05-07-2008, 11:02 PM
odepaj's Avatar
Killer of threads
Pretty soon hopfully! I need some koni's and GC's (or Mychailo's springs) first though!
I found an awesome highway just west of College Station that we could turn into a once-in-a-blue moon type drive.
Texas Highway 166, its 15.57 miles long and the speed limit is 65mph with most of the turns needing to be taken at 30-35mph to be civilized. It's mixed with some nice long straights aswell (one of them is nearly 2 and a half miles long!) Driving aggressively it took me 15-20mins to complete.
-Dustin
Old 05-07-2008, 11:03 PM
I found an awesome highway just west of College Station that we could turn into a once-on-a-blue moon type drive.
Texas Highway 166, its 15.57 miles long and the speed limit is 65mph (with most of the turns needing to be taken at 30-35mph to be civilized.
is it the yellow or red route?
Old 05-07-2008, 11:04 PM
odepaj's Avatar
Killer of threads
The red and white.
-Dustin
Old 05-08-2008, 06:18 AM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
Another issue to be wary of if you start changing calipers is changing the ratio of piston volume to master cylinder capacity. You could wind up changing the pedal travel distance from slight to full braking. This brake thing is really complicated. I heartily suggest anyone thinking of changing rotor size, or calipers read the article in this month's Grassroots Motorsport concerning brakes. It really covers the issue of brake improvements.
This is not an advertisement, but your $40 annual dues payment to NASA gives you a subscription to GRM, which is more than worth the entire dues amount.
____________________________________________
95 LS-i Red, 31,xxx; bone stock for now; Daily Driver
94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light,
2017 Subaru Forester XT, metallic dark gray, 29,xxx
2005 Porsche 911 Turbo S Cabrio, 24,xxx
2006 Subaru Outback LL Bean, 166,xxx sold
92 LSL Dark Teal, Smallcar Shift Kit - sold
Old 05-11-2008, 07:46 AM
Boxersix's Avatar
Boxersix Boxersix is offline
Porsche Autofanatiker
Originally Posted by shotgunslade View Post
Very interesting article in this month's Grassroots Motorsports on brake retrofits. Bottom line, if your current braking system can be put into anti-lock mode, then your rotors are big enough and your calipers are adequate. Obviously, whether or not you can do that depends on the tires you are running. If you are running 255 R-compound slicks, you might need more brakes. I'm running 245/40-17 Bridgestone RE01-R's (not quite R compound) and I can get into anti-lock mode (just barely). Changing the brake system (rotors and calipers) on the front only can throw off the braking balance for the car. Significant improvement can only be achieved if the stock front or rear brake system is significantly out of balance with the other end of the car.
Thermal mass (ability to absorb more heat for a given temperature rise) in the braking system (rotors and calipers) is really important for repetitive hard braking (the track). There is an obvious trade-off between braking system thermal mass and unsprung weight (it's all unsprung) related to handling. The SVX front calipers are medium sized, given that they are only 2 pistons.
I also seem to be using similar braking points (closer in many cases) to other faster cars (of course, they're hauling it down from higher speeds). They pass me on the straight and I'm right back with them going into the corners. They then leave me in the dust exiting the corner.
Don't go for drilled and slotted rotors. I have cracked a front drilled rotor all the way through one side wall (track overheating abuse). Get just slotted or dimpled and slotted. I'm running slotted Frozenrotors (cryo-treated). Even so, they show a pattern of hairline surface fractures from over-heating. Still going strong though.
If you are suffering fade, your need to look at your brake fluid and your pads. I'm using ATE Super Blue fluid, and Axxis Ultimate front pads, Axxis Metalmasters rear (Ultimates not available for rear). I have never suffered significant fade at the race track, although I have glazed the pads (melted the surface). This reduces your braking potential slightly and makes a funny noise when you put on the brakes, but wears off after a short time. Also, you might look at rebuilding (or having rebuilt) your calipers. There is a good chance that age has caused their operation to deviate from spec.
I'll jump in here and back this up about 98% here, with one crutch on the anti-lock theory being that initial bite on some setup may be enough to initiate the ABS sequence at low velocities but nowhere near enough once pad temperature comes up and ~75% of the rotors thermal capacity is met. My 965 had enough initial bite to initial antilock on stock rotors with PFB's in the calipers but ran out of thermal capacity up top. Upgraded to GT3 brakes with ceramic pistons and PFB's all around now to remedy that issue.
Aside from that, one of the most solid informative posts on braking I've read in awhile.
On a side note...........just in my opinion with dealing with my PCA/BMWCCA/Koni-GA race customers ditch that ATE super blue fluid. It's very hydroscopic and absorbs water vapor quite easily. It was common nature here to flush the system after every big race because that fluid would pull moisture and start to boil easily. Castrol SRF is what I run now, and although expensive I usually get a full season on one flush before it becomes water heavy and needs to go. I used to flush the ATE so much over the season I would easily exceed the cost of the SRF fluid. May not be the case in your situation or setup but just and FYI for you incase you start running into a soft pedal constantly.
Old 05-11-2008, 09:51 PM
Nevin's Avatar
Nevin Nevin is offline
I cannot imagine why someone would need different calipers or larger rotors than the factory setup. Unless you are just doing hardcore, highspeed racing, the stock calipers have plenty of bite, and the rotors are large enough to dissapate a good amount of heat.
I have SS lines, ceramic pads, and drilled/slotted rotors and this thing just stops NOW! I'm very impressed by it's stopping power considering the cars heft.
Jesus is the remedy
2015 Expedition EL Ecoboost
Ebony Pearl '95 Subaru SVX LSi
Home of the Bontrager Works 22mm rear sway bar!!
Old 05-11-2008, 10:14 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Yea I had to slam on the brakes this weekend for a very hard stop. My friend's response was "Wow... those are some damn good brakes." It also helps to have some fresh fluid, SS lines, Axxis pads and slotted rotors... and the Koni/GC to minimize the brake dive
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
