Old 04-17-2018, 06:20 PM
briankk briankk is offline
Shock absorbers
Has antbody figured out how to fit bilstein shocks to an SVX?
bk
Old 05-02-2018, 10:31 PM
Re: Shock absorbers
Never mind, I've figured out how to do it..
Old 05-02-2018, 11:59 PM
irox irox is offline
Re: Shock absorbers
Please share!
I'm trying to decide what to do the next time I replace my shocks. I've got AMR shocks on one SVX, and stock on the other.
Was it hard getting the bilstein's on?
Old 05-03-2018, 10:55 PM
Re: Shock absorbers
I haven't actually done it.
Bilstein doesn't make shocks/struts for the SVX, but they do make 'em for the WRX, and turns out that the WRX stuff can be installed on the SVX with a bit of fiddle.
I say again, I haven't actually done this, I read about it on the internet, it must be true...
Old 05-04-2018, 01:36 AM
jetboy's Avatar
jetboy jetboy is offline
Very Terrific Driver
Re: Shock absorbers
K-Staff in Japan has two Bilstein solutions:
1) Inserts into OEM strut casing
2) Full coilovers
Both bolt in. You will have to try their web page.
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 05-04-2018, 04:31 AM
Blacky Blacky is online now
Re: Shock absorbers
https://k-staffcar.amebaownd.com/ or http://www.k-staff.net/
I hope you can read Japanese.
Old 05-05-2018, 08:39 PM
Post Re: Shock absorbers
Been wishing I could speak Japanese for near a week now, still no go..
Old 05-06-2018, 03:42 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Re: Shock absorbers
I ended up using Koni inserts with the following Zoom lowering srprings - dropped about 1.5" to 2"
https://www.jauce.com/auction/w230490678
Old 05-07-2018, 07:33 AM
Re: Shock absorbers
I don't think spring rate or sagging is the problem with my car, I think the struts alone are the problem.
I live 20 miles up a mountain am very experienced mountain driver. One local tricky bit is approach to a local bridge, closing downhill right turn, final twist is narrow bridge entrance while turn continues to close. Transition from downhill to flat, pavement goes from asphalt to cement, at about 7/10 the SVX crashes down on all 4 corners. (the one time I tried it). Yet in "normal" driving, where suspension uses maybe 2/3 of it's travel, everything is fine. I suspect OEM shocks have lost pressure...
