#286
Re: Gearshift Maps
No I haven't
#287
Re: Gearshift Maps
#288
Re: Gearshift Maps
#289
Re: Gearshift Maps
I would like to add here that I drove a 97 for the first time today, and it seems as though the shift maps are much different. 3rd gear holds even under light-no throttle up to about 35 mph instead of shifting to 4th around 27 or 28 mph in earlier models that I have and others that I have driven. I can't recall the other gears as I was just astonished at the higher 3-4 shift point.
#290
Re: Gearshift Maps
Phil,
I made a definitions file to configure my ECUtuner software for communicating with the TCU so one of my customers can do some diagnostics on his transmission (and of course am posting it for public use and hopefully expansion). It doesn't have any of the table/map locations in it yet but it does have the select monitor parameter locations and diagnostic and switch bitmaps. If you could give it a quick look to see if anything doesn't match with what you know I'd appreciate it. http://www.ecutune.com/ecutuner/defi...efinitions.xls |
#291
Re: Gearshift Maps
Hang on, just downloaded and opened....
Will go for a drive (to the salt mine) and report back in two hours . Tapani |
#292
Re: Gearshift Maps
Works like a Buick (a traditional saying from northern Finland) .
Tapani |
#293
Re: Gearshift Maps
I played around with the ECUtuner and picked the brain of the TCU.
The Erev (rpm) figure seems a bit odd... at an indicated 2000rpm the ECU side says 2000 rpm and the TCU shows 1550 rpm (15500rpm with Phils original formula rpm=value*250). I hooked up a scope to the pin 16 in the B61 ECU connector and it shows 10,2msec between ignition pulses which equals to 1960 rpm (three pulses per rev). The pulse height is 11,2V - should be good enough. Same figures at the pin 5 in the B67 connector of the TCU at the other end of the wire and all figures act logically thru the rev range. With ignition on and engine off the TPS signal at the ECU is 0,49V with a closed throttle and 4.0V when floored. The same figures at the TCU are 9,8% and 80% with this definition file. Battery voltage at the ECU is 12,69V while the TCU shows 11,84V when the battery terminals show 12,4V with a digital multimeter - all this with ignition on and engine off. At idle all voltages are very close - 13,4V. Strange, eh? Everything else I have looked at seems logical. Any comments? The ECUtuner is very nice - so nice to see how the MAF saturates at 5500rpm (and the fuel cut steps in) with a boost level of 0,3bar... no intercooling or larger MAF, injectors and stage 2 (yet)..... Kind regards from Finland, Tapani |
#294
Re: Gearshift Maps
Ok,
The reason why I looked at the TCU values is that for some reason my 4.444 geared car does not up shift at the rev limiter set in the TCU. Another thing I noticed is that it will down shift to a gear too low at practically any speed, for example if I floor the throttle at 75mph while in 4th it will down shift to 2nd and over rev the engine (6500rpm equals to app. 65mph with 4,444 gearing in second gear). I looked at the shift maps on Phils site and noticed that the vertical (+horizontal) 100% threshold to prevent unwanted down shift is missing on several down shift maps, i.e. the line continues horizontally at 88% all the way to the right. The ukm, usm and jpm maps seem to differ in this respect. Sean486 made some tests on his 4.444 geared car, which does shift up at the set 6580 rpm and maybe 65mph. When he floors it at a tad over 70 mph while in fourth the transmission shifts all the way down to second (first?) and the engines goes into red before shifting up to third. After talking to Michael we believe that these thresholds should be added in all maps and we will experiment on this. Any input from other people with 4.444 gearing regarding what these thresholds should be would be greatly appreciated. Tapani |
#295
Re: Gearshift Maps
Are you looking at the actual hex values or Phil's graphs?
The horizontal lines you refer to are actually somewhat misleading. Phil followed the format established by Subaru in the service manual. I personally believe that a straight vertical line would more clearly represent the actual values stored. Perhaps identifying a specific market would be helpful. One can assume you are in Drive. |
#296
Re: Gearshift Maps
I'm looking at Phils lines, there's an excel sheet with all numbers on his site. And yes, I'm in drive.
In the usm drive maps the gear 3 down and the gear 2 down lines never reach 100%, but stay at 88%. The 100% threshold prevents down shifting. Here's what happens, an unneccessary down shift to second, over rev and up shift to third: http://s644.photobucket.com/albums/u...t=IMG_0456.mp4 I think the down and up shift lines should never cross. So the thresholds should be added and in a 4.444 geared car at lower speeds than the OEM maps. All maps are TPS vs VSS, not rpm. Tapani |
#297
Re: Gearshift Maps
Now you're referring to gear 3 and 2? If your in 4th, that's the only map it will look at. This is an Apple II era computer. One thing at a time and wait for it to get the job done. I'm going to send you a picture of my TCU program that shows the graph and values in decimal. I don't see any holes.
I don't have a car with a 4.44 here (or time to get to where I might go this fast). I'm not inclined to ask my daughter to perform this test. However, I'm sure I've punched them at such speeds and they have downshifted to 3rd without visiting 2nd. Seems to me others here with 4.44s also have heavy feet and would have noticed this problem. Don't kill the messenger! |
#298
Re: Gearshift Maps
I didn't quite follow... Do you mean that the tranny will never shift two gears down? If there's nothing (a set threshold) to stop it from shifting into second (or even to first) at a too high speed then it will - if you are going too fast for second gear (over ~85 mph with 3,54 gears, ~65 mph with 4,444) it will over rev and then shift back up to third. Is there something I'm missing ? Other people with 4,44 ? Stock or modified TCUs? Kind regards, Tapani |
#299
Re: Gearshift Maps
All I can say is that the TCU will not tell it to shift up or down more than one gear at a time.
#300
Re: Gearshift Maps
Basically there are two, maybe three, things you need to do for a 4.444 swap.
Firstly there are some diff-ratio constants in the TCU which you need to adjust. The way these work is slightly different depending on whether you have JDM, Euro or USA style TCU. Secondly you need to scale the shift and torque converter maps by the percentage difference between diff ratios. Experience shows that it is better to scale maps using software than try to manually edit them. Thirdly, if any of your individual gears are different you need to change the gear ratio constants. I did a 4.444 TCU for Ron (NeedForSpeed) in California, I'm sure he'll chime in and tell you how it compares to the stock TCU.
