Old 05-28-2003, 04:54 PM
svxeno
HELP!!! Tranny trouble and shift kit
I need help bad...
I just had my tranny re-rebuilt and had the Transgo shift kit installed.
4 days later the tranny is slipping at start off and between every shift. Before this started I really didn't notice much difference in the characteristics of the tranny, as in the feel of the shift and when it shifts. I understand there are other benefits to the shift kit, I expected more. Should there be more?
Also, could the misapplication of the kit be causing my new troubles?
I have to get this thing back in right away so any "quick" response would be appreciated.
Randy ii
Old 05-29-2003, 09:36 PM
Earthworm's Avatar
Meow!
Wish I had a good answer for you. The only time I've seen a tranny slip from a stop it was low on ATF.
Old 05-31-2003, 12:23 PM
dekidd7457
Tell your mechanic to check the brake band adjustment. Just a possibility. I am in the process of rebuilding my 92 right now. Don't run the trans any more than you have to until the problem is fixed. Slipping can cause irreversible damage.
Old 05-31-2003, 01:10 PM
svxeno
de,
Thanks for the reply. I have it back again and it's fine now. There was a problem with the a duty solenoid. The car is now happy and so am I.
Good luck on your rebuild. You might want to squeeze a cup holder in there somewhere.
Randy ii
