Old 12-21-2004, 01:32 PM
svxsubaru1's Avatar
Just called up a dealer and got the part numbers for the pistons, theses are standard size pistons, not over bored ones.
Ej22t
left side Right side
12018AA340 12013AA340
12018AA350 12013AA350
12018AA360 12013AA360
EG33
12018AA490 12013AA490
12018AA500 12013AA500
12018AA510 12013AA510
EJ22 90-94
Left side Right side
12018AA231 12013AA231
EJ22 97
12006AA420 All the pistons are the same left and right.
EJ22 98-99
12006AA490 All the pistons are the same left and right.
All the part numbers for the ej22t, Ej22 and eg33 are diffrent.
Old 12-21-2004, 02:14 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Ej22t
EG33
Very interesting. The ej22t and the eg33 each have six different pistons. There may be some truth to the interchangeability rumors.
They both list on subaruparts.com as $61.14 each.
All right, who has a micrometer and $130 to spend on some R&D???
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 12-21-2004, 02:27 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
I would imagine that the 6 different pistons is accounted for by the bore size matching subaru did to ensure tight tolerances and smooth running....
I don't see how the numbers really tell us anything
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 12-21-2004, 03:18 PM
svxsubaru1's Avatar
I think your right, I think there for a more percisley built enigne in terms of weight also, maybe the rods were harder to machine to a cetain weight so they balence it out with slightley heavier/lighter piston. I specificley asked for pistons that werer not for over boarded engines, when i asked for the part numbers.
mohrds's Avatar
It was more of a "it wasn't shot down yet". If the ej22t would have had the same piston for all banks, then it for sure wouldn't fit the eg33.
This might kill the thought. The ej22t has a 9.69 cm bore according to http://wac.addr.com/auto/obs/turbo/ejcalcs.html
The SVX has a bore of 9.999 cm.
That would lead me to believe they are not compatible.
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 12-21-2004, 03:25 PM
Word to Yo Motha
Yeah, this is what I was talking about:
http://www.subaru-svx.net/forum/show...bore+tolerance
Collin
1995 L AWD
Locker
Old 12-21-2004, 03:26 PM
Word to Yo Motha
Doug
Now that definitely puts a damper on things....
Collin
1995 L AWD
Locker
Old 12-21-2004, 03:48 PM
Doug
Don't know about that Doug, my WSM has the bore at 96.9mm,with a stroke of 75mm.
Old 12-21-2004, 04:56 PM
Pistons are different compressino ratio.
Been having a look at the site that you put up Doug. It shows the MY90.2.2, and the MY91,2.2T specs. The cylinder head volume is the same for both, but the piston volume is different, to give the different compression ratio.
So it looks like the pistons are different and are the cause of the lower ratio. Would do the same for the Svx.
The other point is the pistons that are different on each side, is because they use a offset little end pin to reduce piston slap.
Old 12-21-2004, 05:13 PM
mohrds's Avatar
Interesting...
1994 LSi (4/93)
2000 Ford Excursion
Old 12-21-2004, 05:26 PM
mohrds's Avatar
Re: Pistons are different compressino ratio.
Now I want to know what the piston volume is on the SVX
According to Wayne, the piston volume on the ej22t is 28cc in volume compared to the 14cc for the ej22.
If we were to guess the SVX pistons were 14cc, that would also lower our compression to 8.0:1
The more I look, the more it appears that the EG33 is a MY90 EJ22 design with two extra cylinders, new DOHC heads and intake.
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 12-21-2004, 05:29 PM
drivemusicnow's Avatar
Poor College Racer
yeah.. i was pretty sure it as 9.69 for the SVX...
porsche 911 turbo is 9.999 though maybe it was just wishful thinking.
if we already have forged crank and rods, i believe with a bit of machining these pistons would work. but i do think it will come down to someone trying.
Does anyone know the head volume vs piston volume with from the eg33, ej22, and the ej22t??? this would be mighty helpful
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 12-21-2004, 05:46 PM
Clearance volume.
Working with the figures posted, the ej2.2 has a clearence volume of 65.7cc to give a ratio of 9.4:1
Working backwards the SVX has a clearence volume of 61cc to give a ratio of 10:1. So if the ej2.2t pistons were fitted ,it wound bring it down to 8.6:1.
Looks good guys
Old 12-22-2004, 12:58 AM
I double that!!! they do not tell us much.
of course they have different numbers, at the end it is a legacy engine and an SVX engine with different specifications, but the bore size is what counts!!!!
Old 12-22-2004, 01:17 AM
guys why are you all focusing on subaru pistons?? can't we dig up larger bores pistons from other manufacturers? Mitsubishi? Ford?..... the SVX bore as said is 9.99 cm in bore whereas the highest bore of another subaru turbo is 9.96 cm.
I prefer finding a 10 cm or 10.1 cm bore to fit our car, because when dismantling the engine some of you will get surprised to find that they are having some gaps in their piston chambers... so you will need either to fill it or better shave it a little bit to smoothen up and put higher bore pistons...
