#2776
Installed some Subaru emblems on the wheel center caps. Wheels are from a 2015 Honda Accord, 17x7.5, +55mm offset (same as SVX), with 235/45 tires. Also added "3.3" and "AWD" badges at the rear part of the front fenders. Got the wheels off Craig's List, and the badges off eBay. The "3.3" badge is an OEM Kia part, and the "AWD" badge is a generic badge, not model specific (as far as I know). "3.3" badge was around $15, and the "AWD" badge was less than $10.
#2777
GD Photobucket is giving me issues trying to copy the img url, so I had to put them as attachments...
#2779
Just replaced the valve cover gasket and timing belt.
#2780
Roof Repainting
When I first bought my car I discovered that the previous owner had an idiot detail the car at some point. Said person apparently left a running rotary buffer sitting in one place for too long, burning a hole in the paint on the sunroof. Once I washed the car, it looked horrible.
It looked much better after I corrected the paint, but still was beyond anything I could do, so it had to be repainted. I'd gotten a quote for wrapping the roof which cost a good deal less, but I decided to bite the bullet and have it done properly, and it looks much, much better. This car has needed a lot of work, but is really coming along nicely. Despite the low miles it will never be as nice as some here — simply due to lack of care from the previous owners — but it is in much better shape! First two pictures show the roof when I first got the car, after a thorough washing. Third picture shows the roof after I'd corrected the paint, which brought the burn out very clearly. The last two are post painting. It will need a month to cure before I can give it a light polishing and then seal it with a glass coat. Hopefully it will never look that bad again...
SvXit "Flossie" - 92 black over pearl LS-L (sold) "Gorgeous George" - 98 Audi A8 (traded) "Gorgeous Genny" - 02 Audi S8 (sold) "Green Giant" - 00 Land Rover Disco II "Grey Wülf" - 05 Volvo S60 R "Silver Surfer" - 92 black over liquid silver LS-L "9 of 7" - 97 bordeaux pearl, formerly with Earl Steele |
#2781
Looks good.
Do you mind posting the name of the shop you had paint it?
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
#2782
Re: Roof Repainting
http://www.subaru-svx.net/forum/show...t=roof+repaint
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
#2783
http://classicautobodywaldorf.com/
#2784
Re: Roof Repainting
The trim under the rear windows is a little faded, but I'm certain I can polish them and get them in much better shape. same goes for the trunk and wing. The fade spot has been an eyesore since I bought the car. Didn't want to $pend on it, but I knew it was one of those things that would be 'one and done,' as long as I can keep a glass coat on it and not leave any tree sap or bird crap on there for too long.
#2785
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. |
#2786
#2787
Created a version 2 of how I have a cone filter mounted in the car. This one uses a 3" to 2" rubber coupler that I found at Home Depot for $7. The OD of the larger end is the same as the OD of the metal plate, and the OD of the smaller end fits perfectly inside the cone filter. I slipped the filter over the smaller end, then used Gorilla superglue gel to mount the rubber coupler to the metal plate, let it cure for about 15 minutes, then installed it. Lucky there's that accordion section in the intake piping, I had to compress it almost all the way to squeeze the filter into the old airbox location. Also had to remove the nut that held the fender airbox inlet piece in place, so it could be pushed back flush with the inner fender, so the cone filter had a little more room. Should work much better than the previous way I had this mounted, so I'll find out next time I take her out.
1997 Subaru SVX LSi Honda Accord wheels 17x7.5, 235/45s, 5mm rear wheel spacers; "3.3" and "AWD" badges on front fenders; AMR radiator/fans; lowering springs, s/s brake lines, drilled rotors; Stebro exhaust with quad tips, mid-muffler removed; tinted windows. |
#2788
Why go through that trouble to create a hot air intake? Do you plan on creating a box to isolate it?
#2789
I've heard stories of the infamous "hot air intake", so where's the scientific evidence to support this story? I know, I know, common sense should tell someone that removing the airbox, which has a teeny tiny air inlet from the fender, and replacing it with a filter that's attached on the end of the MAF sensor will draw in much warmer air. Well, there's common sense, and there's scientific evidence. Has anyone actually measured the temp difference at the MAF sensor between the stock airbox setup and any kind of short intake setup while the car is in motion?
#2790
Went to the local Subaru dealer to get a labor estimate to install a bunch of parts I have, to get a benchmark for other estimates. I asked for a labor estimate to install 4 s/s brake lines, 4 lowering springs, 4 rotors / pads / wheel seals / bearings. Any guesses on what their estimate was?
Can you believe their estimate was $3200???!!! WTF, over?! Guess it looks like I'm going to use an indy shop that quoted me less than $800 for the same thing. And I don't have the knowledge, tools, or patience to do it myself, so trying to find the lowest responsible estimate is a good thing for me. But $3200? That's criminal...
