Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Brake Upgrades
Old 06-11-2014, 04:30 PM
'E''s Avatar
'E' 'E' is offline
Re: 6 pot mono block Brembo calliper kit
Originally Posted by SilverSpear View Post
E, is this the dust shield needed to be installed in the back for the Calipers?
Anything else is needed to make it work on the SVX hub (Hand brake, ABS Sensor, brake lines, etc..)?
That's all you need, all the original Svx stuff bolts to it
92 pearl SVX about to revive
92 Black 4ws (Jap spec) SVX
93 black SVX
93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear
95 bright red SVX
96 emerald pearl SVX about to revive
Old 06-12-2014, 12:20 AM
Thanks man.
Is this the correct part number?
Old 06-12-2014, 03:04 AM
'E''s Avatar
'E' 'E' is offline
Thanks man.
Not sure but as long as it's 01-07 Sti then it's fine
93 black SVX
95 bright red SVX
Old 06-13-2014, 03:02 PM
Gr8, 10x....
Old 11-02-2015, 02:04 PM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
What is the current price (with shipping to USA) and availability for these? Any way of making a kit for 17'' wheels?
Thanks,
Sam
Sam
Old 12-04-2015, 07:31 PM
'E''s Avatar
'E' 'E' is offline
Hey sorry for the late reply
Caliper and pads $1,977 plus shipping
Rotors $200 (you source them locally)
Brackets $200 (if there is a group buy of 5 or more otherwise they are $400 a set individually)
93 black SVX
95 bright red SVX
