Do Brake Rotors Warp
The Answer is: Yes. Just got an opportunity to take my wheels off and look at the brakes since my track day. Brakes have been making grinding noises and vibration since I got back from the track. Thought I might have ground the pads down.
But.... Plenty of pad left. Smear around the front rotor at mid span is rust, not melted pad stuff. Essentially, the rotor has warped such that there is a depression running around the rotor midway between the hat and the edge of the rotor. That region is not being wiped by the pad, so rust is left. These are Bien's drilled and slotted and have never given me any problem before. Pads are Axxis Ultimate. Where to go from here? Have a track day at Watkins Glen September 18, so time is of the essence. Clearly, I'm at the point of putting way too much stress on the brakes for even drilled and slotted to avoid warpage. Have reviewed previous posts, especially from Paisan, who used to be an SVX track-day person, now 94 Turbo LGT, and who was my instructor at a recent SCCA event. He recommends slotted strongly, but advises against drilled. Have an e-mail in to Frozen Rotors, looking for cryo-treated slotted brake rotors. Think maybe cryo treatment is a strategy to avoid warping. If any of my fellow SVX-net members have their secret big brake solutions ready for beta testing in the next 2 weeks, sign me up. Need to get something by Friday, September 15, so can insall that weekend. Will keep all posted, Welcome any suggestions.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; 07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
get them turned
Cross Drilled have more tendency to warp. The holes weaken the overall structure of the disk. Larger vented ones (and/or slotted) would be far less likely to warp.
Shop refused to turn drilled and slotted rotors. Am getting new slotted only.
Be sure to torque them to the proper ft lbs. That will help and is a factor on the stock ones when they warp.
. Earl .... ... .... ><SVX(*> Subaru Ambassador [COLOR=silver]1992 Tri Color L[/COLOR] ~45K (06/91) #2430 1992 Dark Teal LS-L ~184K (05/91) #0739 1992 Claret LS-L ~196K (05/91) #0831 1992 Pearl LS-L ~103K (06/91) #1680 1992 Pearl LS-L ~151K (06/91) #2229 1992 Dark Teal LS ~150K (07/91) #3098 (parts car) 1992 White LS-L ~139K (08/92) #6913 1993 25th AE ~98K (02/93) #164 1993 25th AE ~58K (02/93) #176 1993 25th AE ~107K (02/93) #215 1993 25th AE ~162K (02/93) #223 1994 Laguna Blue Pearl LSi ~124K (1/94) #2408 1994 Laguna Blue Pearl LSi ~144K (10/93) #1484 1994 Laguna Blue Pearl LSi ~68K (10/93) #1525 1994 Barcelona Red LSi ~46K (02/94) #2624 1994 Pearl LSi ~41K (12/93) #1961 1995 Bordeaux Pearl LSi ~70K (02/95) #855 1996 Polo Green LSi ~95K (03/96) #872 1997 Bordeaux Pearl LSi ~55K (08/96) #097 2003 Brilliant Red LS1 Convertible ~29K (04/03) #8951 1999 Magnetic Red LS1 Coupe ~33K (04/99) #6420 My Email | Old Locker | New Locker | Picture of 15 of the 19 |
Earl:
Was reading some previous posts about warped rotors, and saw the issue of lug torquing several times. Went out to check my lugs and they were on way too tight. For whatever reason, I forgot to check them the last time I went to the track, and I guess the shop that did my last pre-event tech inspection put them back on with an air-wrench. Came back in and saw your post mentioning this issue. Will definitely remember always to check the tightness of the lug-nuts after I take it to the shop, no matter what the reason.
On both, of the front disks? Is the mark the same, on the other side of the disk. Or the opposite, with the edges rusty and the center shinny? A photo shot would be great. Harvey.
Harvey:
The patterns are the same. By the way, for those who are buying zinc plated rotors, these are about 2 years old, and, as you can see, the hat is rusted, as are the drill holes and the rotor edges. Not pretty.
Whole problem!
I'd like to see the pads and how the drilled holes line up with the cast vents, But it certainly looks like it is caused by the drilling of holes through the disc.
Vented discs should not be drilled, as it interferes with the way the air flows through the vents, to cool the disc. The air should enter the vents in the center of the disc, to flow through the vents, to exit at the outer edge, due to the centrifugal force generated. When holes are drilled through these vents, the centrifugal force will cause the air to enter the drilled holes, and flow out the edge, to short circuit the vents flow. This will cause the disc to cool at the outer edge, but overheat in the center, as the air is not flowing through this area. Harvey.
Harvey:
Probably so, but these are the same RaceConcepts rotors that many people on SVX-net have. My next set of rotors will slotted but not drilled, maybe dimpled. In any event, I'm going to make a decision tomorrow, whether or not to get new front rotors, right away. I'll probably go out and try the home rotor turn on the expressway first. I know that sometime in the future, I will have new big front rotors courtesy of another SVX-net member, but don't know when that will be. If that is the case, I'll probably go inexpensive for the new rotors. On the other hand, I'm waiting for a quote from Frozen Rotors to see what their cryo-treated rotors cost, and to see if they have slotted and dimpled. Might be able to use them for a while, then sell them to another net member. Just want to make sure the diagnosis is correct. Definitely warped. Probably because of too tight lugs and an overly active track day.
Dan,
I've got two sets of the RaceConcepts dimple drilled and slotted rotors - purchased before Wood sold the company. I didn't know they even sold drilled versions like the ones on your car. -Bill
my ebay cryo treated slotted bradis still look good after about 4 years but I guess part of it is due to no salt down here.
brakes
get the big brake kit for the svx. you will probably need new wheels as well depending on your wheels. of course you already have ss brake lines?
