Old 01-09-2006, 04:22 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Oxygen sensors
Code 32 and 37 showed up. So I replaced both oxygen sensors, but the codes still show up. Any suggestions?
Old 01-09-2006, 11:04 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Did you clear the codes out of the computer? If not, go to the how to section for directions on how. You could also disconnect the battery overnight and that will do it too. Just make sure if you have a cd in the cd player you leave the door open because mine ejects it into the door when I reconnect my battery. Just a little tip.
Old 01-10-2006, 03:04 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
Overnight? 5-10 minutes is enough..
Brian
Old 01-10-2006, 01:01 PM
spinn360's Avatar
spinn360 spinn360 is offline
Both codes showed up on mine. I havent got to work on it yet but the TPS is what I believe is the culprit. Look at my post Power mode all the time. If the codes dont clear and keep re-appearing.
1989 Subaru XT6 130k
1992 Subaru SVX 120k
1993 Ford Probe 30mpg 213k
1989 Subaru XT6 150k
All good and running
Old 01-10-2006, 08:05 PM
dannmarr's Avatar
I work for my SVX
I tried clearing the codes with no success. I disconnected the battery over night and it worked. Thanks to all!
Old 01-10-2006, 10:11 PM
Budfreak's Avatar
Banned
Glad to hear it. Hope all is well now.
Old 01-11-2006, 05:48 AM
dannmarr's Avatar
I work for my SVX
I've had my SVX for about one year. I spent over 5,000 to get it in tip top shape. I believe I'm finally finished fixing it. I did not know anything about auto mechanics until I bought my car and used this forum. The only minor problems I still have are; The gas gauge and the occasionally starting problem. I haven't found anyone who has a solution to these problems.
