Old 09-26-2017, 09:56 AM
Paul Hook Paul Hook is offline
1992 SVX Crank Position Sensor
Greetings! I need a crank position sensor for my 1992 SVX. I am located in Carlsbad, CA.
Thanks for your help, Paul.
Old 09-27-2017, 11:16 AM
Re: 1992 SVX Crank Position Sensor
A Mid 90's Legacy/Impreza one can be used...same sensor, just slightly different mounting tab...and they can be had cheap on roakauto.com
Old 09-28-2017, 08:11 PM
Dan sr Dan sr is offline
there are 2 crank sensors ,and one can be altered from legacy,;
which one you need? Dan sr.
partstogo@gmail.com
Old 01-21-2019, 10:07 AM
Guyver280z's Avatar
Guyver280z Guyver280z is offline
Send a message via MSN to Guyver280z
I need a crank position sensor for my 92 SVX, but I don't know which one is the bad one, just got a faulty crank sensor code. How do I know which one I need and can I just replace both with the same one from a Legacy?
Thanks!
Old 01-21-2019, 10:13 AM
Try a new one on one of them, if that doesn't work, put the old one back, and try the new one in the other one.
Old 01-21-2019, 12:13 PM
For the cost, I would go ahead and change both. I went through this late last fall. Somehow both sensors failed. I tried changing one and then tried the other. It wouldn't start until I had replaced both with new ones. I would have saved myself a lot of time and assembly/disassembly if I had done both at once.
I think they are easily damaged when removing them. especially if they are stuck. I sold a known working one to a member a few years ago only to have him send it back because it didn't work.
Old 01-22-2019, 07:45 PM
oab_au oab_au is offline
Thanks!
The code No. 11 is crank sensor No.1.
Code 29 is No. 2.
Code 13. is the cam sensor.
No.1 sensor is on the left hand side. No. 2 is to the right, under the alternator, looking from the front.
Cam sensor, is on right side of engine near the battery.
You can replace them with legacy sensors, the No.1 is different, but you can fit the Legacy one turned slightly, with the bolt down beside the bracket.
One Arm Bloke.
Tell it like it is!
