Stop Lamp???
I have had my car for a while now but only now has the Stop Lamp (!) light started coming up on my dash when i brake. What does this light mean and why did it only start coming on now???
Re: Stop Lamp???
isnt it one of your brake light burnt ?
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008" rest in pieces Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill |
Re: Stop Lamp???
It means that the brake fluid level is low, which will happen when the pads wear down past half way (or if you've lost fluid due to a leak).
Added: Oops. Wrong warning lamp. Ignore this.
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses Last edited by SVXdc; 04-04-2009 at 12:30 AM. |
Re: Stop Lamp???
"Stop Lamp" means one of the tail lights has excessive resistance in the circuit (usually a burnt out bulb filament) it only illuminates when the brake lights are on. A low fluid level would cause the (!) BRAKE light to illuminate.
2007 GS 450h-Active Stabilizer/Radar cruise 1994 L Blue 3.70 VTD ASE Master Automobile ASE Advanced Level Specialist Toyota Master Diagnostic Technician (former life) |
Re: Stop Lamp???
That's an electrical impossibility.
Re: Stop Lamp???
Its just a brake light that is dying... but not dead.
The easiest thing to do is buy 4 new brake light bulbs and replace them all at the same time. That way the amperage matches and the "stop lamp checker" (which controls that light on the instrument panel) will be happy. The stop lamp checker uses the amperage difference between the trunk panel and the two body-mounted stop lights to determine if a bulb is bad. Very similar design to a GFCI outlet in your house. The stop lamp checker works by separating the stop lamps into two circuits, each with two bulbs. The two center panel lights are one circuit and the two outside lights are the other. The two circuits each go into a sensor and each current draw is measured. If it is not in balance (ie, one circuit has two bulbs, the other only has one working) the stop lamp on the dash triggers. The manual tells you the only "fooled" instance. If one bulb from the center panel is burned out and one bulb on an outer light is burned out, the indicator will not come on. It has a fail-safe so if all four bulbs are burned out (zero current flow) it triggers the light. If you put higher wattage bulbs in the center panel but regular bulbs in the outer lights, it will trigger an indicator even though all four bulbs light. If you have unmatched wattage bulbs, the difference in amperage can be enough to trigger the checker even if all four bulbs work. Bulbs are dirt cheap so when I have one go out, I replace all four with the same. .
Re: Stop Lamp???
Sorry, I misread the original post.
It's been a long time since I read the owners manual . I've never seen the Stop lamp in operation (I don't even recall seeing it when first turning on the ignition). For that matter, I've never had any of my marker, turn, or brake bulbs burn out. I think the low-beam headlights are the only exterior bulbs I've had to replace (and I've had the car since new). Quote:
The diagrams I have (I just checked both 92 and 96) show all four brake light bulbs plus the center "high mount" wired in parallel, with one side tied to ground and the other going into (and getting the +12V from) the Stop lamp checker module. That would imply that the module looks at the total current draw, and turns on the "Stop" warning lamp when the current goes lower or higher than some range it thinks is normal. The diagrams show the module connects via a 4-pin plug (+12V in from brake pedal switch, control output to Stop warning bulb, ground, and +12 out to brake lights).
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses |
Re: Stop Lamp???
But definitely a "fluid" possibility!
Keith |
Re: Stop Lamp???
Additionally, the brake stop light sensor can be defective and often is.
